Question about Makita Hammering
Makita jackhammer not hammering It turns on fine but no hammer when plug in it runs for a while then trips breaker It stop working after someone used it with a thin cord started smoking
    Top Expert:
  • Makita Master
  • 30,858 Answers
That doesn't sound good. You need to take it to a service centre for testing and repair.
Makita Authorized Factory Service Centers
Posted on May 20, 2016
Anonymous
SOURCE:
Anonymous
  • 2712 Answers
SOURCE: Breaker Hammers size question
After considering the application work, determine the carrier on which the breaker will be installed. Gorilla Hammers has assigned a 'Recommended Carrier Weight' range to each breaker. If the operating weight of the carrier falls within this range, the carrier will safely handle this model of breaker. If the desired breaker falls outside of this recommended carrier weight range, the carriers lifting capacity and oil flow will need to be verified to ensure a proper fit. Lifting Capacity: Provided the weight of the breaker does not exceed the maximum lifting capacity at any position, the carrier is assumed to be stable. On most loader backhoes and excavators, the maximum lifting capacity is lowest when the boom is at full reach. This is the value that must be compared to the operating weight of the breaker. Oil Flow and Operating Pressure: A required oil flow range is specified for each breaker. Oil flow to the breaker within this range is adequate for operation. However, for maximum productivity the carrier should be capable of providing the maximum required flow. Compare the maximum oil flow requirement of the breaker with the oil flow capacity of the carrier. Remember the breaker operates at 1500-2500-psi. therefore, oil flow should be evaluated at operating pressure.
Posted on Aug 27, 2008
Anonymous
  • 141 Answers
SOURCE: I have a Bosch brute jackhammer, I need the tool
You can use an adjustable face spanner wrench to remove that cap. I don't remember the pin size but you can measure the holes and get the appropriate size. You can remove the whole plate with the armature by undoing the 4 cap screws. Prior to removing the motor plate you have to remove the handle plate from the axle that goes through the body. Undo the nut that holds the assembly on and slide it off. You can now remove the Armature plate. After removing the cap screws pull the assembly out about 1-2 inches. You will see the wires that go to the field attached to the brush holders. Remove the screw that holds these wires to the brush holders. You can then safely remove the whole assembly. This also makes it easier to remove that cap plug with the spanner wrench, because you can now put the whole assembly in a vise. I always heat around the cap with a torch before doing anything. Then I tap on the plug with a hammer a couple of times and voila it turns alot easier. Corrosion almost always builds up on this cap because of the different metals. (Steel and Aluminum respectfully)
Your hammer may have a broken connecting rod. To inspect this make sure you ping the cylider and body with marks so you line them up the same way. Then remove the 4 cap bolts that hold the cylinder to the body. Remove the cylinder and inspect the hammer cylinder and rod. If the connecting rod is not broken you will have to inspect the gears and pinions to make sure they are ok.
Posted on Sep 13, 2009
Garry Clelland
  • 251 Answers
SOURCE: Won't Hammer!!
try repacking with grease as per service kit 897
http://www.islandhirecentre.co.uk/docs/spares/B10201.pdf
thats the drawing for it
if that fails then its a replace all seals/o'rings i'm afraid
a fairly big job btw
Posted on Oct 23, 2009
Garry Clelland
  • 251 Answers
SOURCE: I just bought a Bosch
Hi , you can use a tamper plate with it for small jobs , but to be honest i would go for a GSH27 ( easier on the back ) .
Posted on Aug 08, 2010
rowdy45176
David Ford
  • 2176 Answers
SOURCE: milwaukee 5338 breaker hammer stopped
my first question is what did the old brushes look like, was the spring burnt, were the contact faces on the brushes not the same. I would make sure that the brushes move freely in the tubes allowing contact with the armature, to ensure this use your volt ohms meter and place one in at a time and check by inserting your probe on the commutator thru the opposite brush tube and the top of the installed brush. I assume you have one if you indicate the cord/switch are OK. If they were not burnt then the next thing I would look for is a loose connection or broken wire from the vibration of this tool. You can get a breakdown and wiring schematic by going to milwaukeetool.com. I strongly recommend doing this before further disassembly. Let me know
Posted on Aug 02, 2011
Does a makita electrick. Jackhammer take oil or grease and where does it go
The GREASE for this heavy jackhammer
Makita 181490-7 Grease (if there are short carbon brushes to find ) replace all orings gaskets (and looking for an maintenance kit for this machine) 188015-8 thats the better way to service.
Sep 12, 2018 | Makita Hammering
Manual for a Makita Electric Jack Hammer
power cable can be fractured, autostop in carbon brushes activated or an loose contact or broken contact in electric field.
Jul 10, 2014 | Electric Demolition Jackhammer
My hitachi jackhammer runs slow and gets hot
The armature AND electric field must together replaced to get a safe working again, and the defect will not repeat if it be shure have its operating hours on it and give a full service.
May 24, 2014 | Bosch Brute Breaker Hammer 11304
Drill is not hammering
Makita have most cases a problem with the stroke bolt in front of the locking sleeve a broken ring that will blocked the stroke bolt.
In some cases the locking sleeve is also damaged , a rotary hammer is not made for demolition only a little small task but not for a long load , the metal pieces of the machine is no hard enough for long lasting .
Mar 10, 2014 | Makita Rotary Hammer - 240 RPM, 2150 BPM,...
What type of oil
http://www.homedepot.com/p/Makita-Hammer-Bit-Grease-194683-7/205182387
For outside chisels
Inside its depend on the model but most time its a Makita 181490-7 or for the older types Hammer grease Makita P-08361
Feb 19, 2014 | Makita Hammering
Need to change the brushes in my chicago breaker hammer
If change brushes it has having its workinghours Use a service kit for your model if there is support for your hammer ??? on EBAY there is a set brushes parts are maybe hard to find for electrical demolition hammer of this brand.
Carbon Brushes Chicago electric UL breaker jack hammer NEW 46935 harbor...
Jan 30, 2011 | Electric Demolition Jackhammer
I can't get the bit out of the breaker
Sounds like the bit bent slightly and as a result jammed into the chuck. Open chuck as much as possible and have someone pull the bit out while your tapping it with a small hammer. The vibration from the tapping might loosen the bit from the chuck.
Feb 28, 2010 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
I have a old electric 120vac jackhammer (not sure manf.)
usally their is grease packed in the hammer part,you can usally see a plastic type bung(plug)on outter casing
May 13, 2009 | Electric Demolition Jackhammer
I have a makita hr2455x rotary hammer drill that won't hammer
you need to get that service,
the grease causes the hammering.
and probably too much pressure was applied
to it.
Mar 25, 2009 | Makita HR2455X 1" Rotary Hammer Drill
Hammering Logo
1,982 people viewed this question
Top Makita Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Makita Hammering Expert? Answer questions, earn points and help others
