Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Textured door sweats on humid days. Place about dollar bill size looks like light rust. Anyway to clean w/o damage to door?
  • Frigidaire Master
  • 18,157 Answers
There are some products that you can put on rust that cause it to harden and stop if from spreading, You would then have to repaint the door.
Posted on May 20, 2016
6ya staff
SOURCE:
Can I replace insulation in door only?
Hi - I understand that you recently had something heavy drop on top of your Frigidaire Freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Oct 21, 2015 | Frigidaire 5 cu. ft. / 142 liter Chest...
Condensation on top of freezer. It got something very heavy dropped on it. Dented the top corner. Door seal gasket IS sealing properly. is there a way to re-insulate just the door?
Hi - I understand that you recently had something heavy drop ontop of your freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Oct 21, 2015 | Frigidaire 13 cu. ft. / 368 liter Chest...
When I open the refrigerator the freezer pops open
I appreciate your inquiry, Tammy McAninch!
Based off the information you have provided your Frigidaire freezer door pops open when you open your refrigerator door. This can happen with new refrigerators because the seal is new. I understand your question is labeled under model FGHB2866PF. It could be issues with your door not aligned properly and hitting your freezer door to open. I would check the gasket to make sure they are creating the proper seal on your freezer in order to check that you can use a dollar bill. Place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. If you continue to experience issues with your freezer door I would recommend reaching out to a professional for further assistance. I hope this information helps to some degree. -Matt
Nov 17, 2014 | Frigidaire Gallery Series FGHB2866PF 27.8...
Freeze's on bottom 12' on top 40'
Hello Paul Rorrer, thanks for your inquiry!
I see that your question is listed under Electrolux freezer. Please help me understand the question you are asking. Is it freezing on the racks? Or is there a frost buildup? I would recommend turning the temperature down to help alleviate some of the cold air building up inside of your freezer.
Additionally if there is a frost buildup I would recommend checking your gasket to see if it is in good condition. You can do that by using a dollar bill. Place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. If you could provide me any more information I would be happy to assist you. -Matt
Sep 25, 2014 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Freezer not freezing
Hi Kenneth, I am happy to assist you!
If your freezer is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the sealed system that only a professional can repair. This can include the compressor not working correcting, the evaporator fan not turning, or even coolant in the lines with incorrect levels to properly cool. Do you hear the compressor running? If the compressor is running, humming or even a little warm then that is typically normal. I suggest cleaning the unit out including the coils you can reach (typically located underneath or behind the unit). Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bills falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Best of luck!
Oct 13, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire glhs36eesb5
Good Morning Salahuddin, if you refrigerator is not cooling, it could have floating restriction in the line or something more complicated like an issue with the sealed system that only a professional can repair. This can include the compressor not working, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. If the compressor is running, humming, or even a little warm that is typically normal. I suggest cleaning the unit out including the coils you can reach (typically located in the bottom behind the toe grille) and make sure no food items are blocking any vents in the unit. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Jul 24, 2013 | Frigidaire Freezers
Whistling noise freezer close
Hello sangpark003 - Often when the unit is making a whistling noise, it is because it is pulling air from the outside. Sometimes a poor door gasket could be causing the whistling. You may check if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocking by anything stopping it from closing. However, if issue persists, I would personally contact a professional to accurately diagnose the refrigerator to determine the root cause to reduce the risk of unnecessary parts or to confirm if it is a normal operation noise.
Mar 28, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Change digital thermostat on frigidare freezer
Not hard to do. Just make sure you have it grounded well. Very reliable. Just follow instructions to the tee.
Jan 29, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Does not get cold
Hello bprice7777 - When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If any suggestion proves to be ineffective contact a professional to move forward accurately.
Nov 13, 2012 | Frigidaire 5 cu. ft. / 142 liter Chest...
My freezer has condensation inside
Hi - From what you have described it sounds like the freezer has a poor door seal. When cold air and warm air outside is entering it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit.
Oct 06, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
872 people viewed this question
Top Frigidaire Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Bruce Denton
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
