I have a Okidata 9500 DXN that is having issues with the following:
Refilling Toner.
How to clear waste toner from cartridge.
How to clear toner sensor error.
How to remove Tray to remove paper jam.
Your asking a bit much
1) - Power ON printer while holding both the + & - buttons until “OKIUSER” message appears in LCD.
2) - Press + or – button until “ENGINE DIAG MODE” is displayed.
3) Press "ENTER", displayed will be "DIAGNOSTIC MODE XX.XX.XX S-MODE"
4) Press + or – button until “NV-RAM INITIAL” is displayed.
Half way, dont stop too long it will time out....
5) Press "ENTER" again.
6) Will appear "TABLE 1" message.
7) Press "ENTER" until "EXECUTING RESET" message appear. ...............the "NV-RAM INITIAL" message will BLINK.
Tada....This procedure reset TONER, DRUM, FUSER and BELT...life counts
8) power OFF printer, wait 10 sec, and power ON again..
To access Service Mode in C9300 power ON printer with 0, 1, 6, 7 at same time...you can do some good damage in there!! (I warned ya!)
Resetting consumables for OKI C7300,C7500,C9300 printer I think!
1. Hold buttons 0 + 1 + 6 + 7 on startup.
2. Press button 0 several times until "DIAGNOSTIC MODE xx.xx.xx" shows.
3. Hold buttons 2 + 3 until "ENGINE DIAG LEVEL 4" shows.
4. Press button 1 to scroll to "COUNTER SET".
5. Press button 2 to scroll through menu items (button 6 scrolls backwards)
6. To alter the value of an item, first press button 3 to select the digit to be altered. The selected digit will slowly flash. (Button 3 moves to the right through the digits. Button 7 takes you to the left.)
7. Then press button 2 to increase the value of the selected digit. Press button 6 to decrease the value.
8. When the changes have been made hold buttons 1 + 3 + 5. The screen will flash three times and then an * will appear on the right of the screen. The new value is set.
9. To leave the counter set menus, turn the printer off.
IMPORTANT
Each colour toner counter shows life as percentage used. So a toner showing 30% has used up 30% of its toner. 100% would indicate a near empty toner. This is the reverse of the toner life shown from the "usage menu" when the printer is in normal operation, which shows the toners as a percentage life remaining. You will want toner showing 00%. note:this is oposite of what you see in user mode
Some models exhange these steps
3) HOLD 0 + 4 "ENGINE DIAG LEVEL 2" shows
4) Press 1 to cycle to "fuser unit"
5) 2 to scroll to TONER
REST IS SAME WE WANT TO SET WHAT i GUESS IS AT 100% TO 0%.
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
893
I HAVE AN ODD MESSAGE ON MY PRINTER. IT IS WORKING O.K. BUT IT IS
FLASHING THIS MESSAGE "TONERSNS". I HAVE LOOKED AT THE INFO WE HAVE
ON THE PRINTER, BOTH WHAT CAME WITH THE PRINTER AND IN THE INTRANET
AND CANNOT FIND A MENTION OF THIS. I HAVE ALSO BEEN ON OKIDATA WEB
SITE AND CAN'T FIND A MENTION OF THIS. I REPLACED THE TONER
CARTRIDGE ABOUT 3 WKS AGO AND REPLACED THE DRUM ABOUT THE SAME TIME.
GOT ANY IDEA WHAT THIS IS?
Oki B8300. Had a few problems with it but the toner is brand new. Message tells us to change toner. Any ideas??
