Question about Juki America, Inc Juki MO-644D 2/3/4 Thread Overlock Serger JUKI010
Is there any way to purposefully slow down a serger in a sewing factory
It goes pretty fast then all at once it slows down is there a switch the mechanic uses to do this
    Novelist:
    Scholar:
  • Juki America... Expert
  • 90 Answers
Check the pulley on your motor. Sometimes thread gets wrapped around the pulley and can cause this. If this is the problem, take the belt off the pulley, cut all the thread away and put the belt back on.
Also make sure that your belt doesn't have any oil or grease on it that is causing it to slip when it gets warm.
How is the tension on your belt? It should be adjusted tight enough to run the machine but not so tight you overheat the motor. When it is not moving, hold both pieces of the belt half way between the machine and the motor and try to force them together. If they can touch, the belt is too loose,and if you can't get any 'give' to try and get the two to touch, the belt is too tight. It should be springy.
Good Luck :)
Posted on Dec 02, 2018
6ya staff
SOURCE:
My baby lock bl5260 serger starts ok but slows down and then stops
If it is a mechanical machine (not computerized), it could be seizing due to old oil that has dried. Mechanical machines, especially sergers, need frequent and thorough oiling (interior moving parts) using a good quality sewing machine oil. Avoid trying to run the macchine until you can get it serviced or the motor could be damaged.
Jan 05, 2018 | Baby Lock Sewing Machines
Sewing speed not properly working
no known fixes just replace with new
Feb 19, 2015 | Sewing Machines
Timing serger needle
If machine speed is not controllable with your foot controller, you probably need a new controller. These items should be covered by a 2 year warranty from Janome.
Jan 10, 2014 | Janome 7034D Sewing Machine
Brother serger slows down
it could be the motor or the power cord or the foot pedal,
check to make sure the power cord and the
foot pedal are connected correctly to the machine.if they are
then the machine and power cord and foot pedal need to be
checked
Nov 13, 2012 | Brother 1034D Serger Sewing Machine
Baby lock bl4 736d serger slows down and stops
Your serger needs service. (clean, oil, adjust, etc.) It may be that the motor is not lubed well enough and as it is being run it heats up and expands which causes it to bog down and stop. I would take it in for service and "mention" this issue while you are there.
Sep 11, 2012 | Baby Lock Sewing Machines
Baby lock serger motor slows down after sewing 20 minutes. Why?
Call your local service shop. Baby Locks in closets for years usually have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Been there, done that.
Jul 22, 2012 | Baby Lock Eclipse Serger
Related Tags: slow sewing stops lock not sewing Print Email Flag Problem with Baby Lock Eclipse Serger I have a Baby Lock Serger BL-90. When it has been on for a while and I'm sewing, it starts t
Perhaps was same as my problem.
Call your local service shop. Baby Locks in closets for years often have this problem The manual recommends annual maintenance by a pro, and they will oil the internal lobes of the feed dog apparatus. It cannot be oiled from the outside, nor with covers off, but must be taken apart. If those lobes lose the oil and heat up you will feel "surging" then slowing repeatedly -- fast then slow then fast etc -- until the lobes over heat and sort of weld themselves to that small barrel looking case. So a Baby Lock can sew, then temporarily be sluggish then later slow till sluggish; and at worst, seem to be doing everything right BUT not advancing the cloth -- that's when the worst damage is done and professional repair is needed. In PA might cost $150 to fix. $70 in parts; $80 in labor (2012 prices)
Jul 02, 2012 | Baby Lock Eclipse Serger
Babylock Serger loosing power
Your problem is probably the stitch length adjustment cam (located on the left side of the machine) To fix this problem you will need to remove the small plastic cap (with red arrow) covering the screw securing the cam. It is usually also necessary to remove the connecting rod/sleeve that the cam rides in. Once both of these parts have been removed, you will need to carefully separate them and resurface the inside of the sleeve. This can be done with a very fine (500grit or higher) emery paper. Once the cam fits inside the sleeve without binding, reassemble using sewing machine oil or lithium grease and adjust feed dog timing.
Jul 13, 2009 | Baby Lock Eclipse Serger
What does the differential feed do?
Get a basic book on serging from your library. The higher the #, the feed dogs infront feed fabric in faster, keeping knits, etc from stretching. It can also gather if you go to the highest #. A slightly lower # the N can be used for slippery fabrics because it slows the front feed dogs, but be careful because it can stretch and ruin the fabric. I have only once needed the lower # for a really slippery chiffon. Start on scraps and experiemnt. It's not used very often unless you sew daily or professionally.
Mar 18, 2008 | Baby Lock Eclipse Serger
Juki America, Inc Juki MO-644D 2/3/4 Thread Overlock Serger JUKI010 Logo
Top Juki America, Inc Sewing Machines Experts
ray gallant
ray gallant
R.A. Ellis
R.A. Ellis
Shirley Neibarger
Are you a Juki America, Inc Sewing Machine Expert? Answer questions, earn points and help others
