Question about Mackie 1604 Vlz3 16 Channel Mixer
Just bought the mixer and when i hook up the mixer to the amp the amp showing it clipping and no sound to the main speakers
    Top Expert:
  • Mackie Master
  • 3,156 Answers
If you are getting signal from you mixer at leaves tha are clipping your amp, then the mixer is working and at least the front end of your amp is working to register the clipping. In that case, your problem is-
1. The amp outputs are blown, check by hooking up to a different amp.
2, The speaker wires are connected incorrectly.
3. The speakers are not working. Try a different set.
Posted on May 22, 2016
6ya staff
SOURCE:
Do i hook up speakers to amp or mixer
You hook them up to the last item in the chain.
If you are mixing instruments into the amp, then the speakers go to the amp.
If you are mixing amplified sound (unlikely), through a mixer, then speakers to the mixer.
Nov 22, 2016 | AMP Music
Just bought the mackie 1604 vlz3 mixer and cant figure out how to get sound to the main speakers, the speakers and amps are connected correctly
Simplest is to use the LR button at the bottom of the channel strips you want to send to the main mix. Make sure you set the gain for each channel in use so that the clip light just occasionally blinked then back off a fraction.
If you want to use sub channels assign the strip to the appropriate one 1/2 or 3/4 and the assign the sub to the main mix and bring the subs up.
May 21, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
Shud i get an external equaliser? i'm using MG166CX 16-Channel Mixer as the main mixer.
An external equalizer will not help this at all. The problem is likely within the amp (feeding the main speakers), the connections from the board to the amp, or the speakers themselves. In other words, the answer would be "NO." Best of luck!
Jan 14, 2013 | Music
How to hook up a gemini amplifier?
typically (unless your useing other gear besides mixer and amp) you'd come out of the L/R outs. ( Main outs ) to the Main inputs of the power amp then out to your speakers (outs of power amp). Now the amp could be in bridge mono or other factors but typically, like i said, just
Mixer Out- Amp In- Amp Out- Speakers.
Oct 22, 2011 | Gemini Sound Products GEMINI XGA 2000 2000...
When we are trying to get a reasonable level of sound for vocals before it gets loud enough to be able to hear clearly with the band playing it starts to clip at the speakers now we are only using this set...
Proper level setting of the mixer is important. HOWEVER if the clipping is occuring at the speakers the only possible problem MIGHT be that you have a supersonic feedback that is saturating the speakers above your hearing range, Be sure you don't boost the highs too much with the EQ as this can cause the feedback that you can't hear. Also make sure that you power the speakers from the SAME receptacle as the mixer, even if it means running an extension cord to bring power to the mixer. This is to avoid a low frequency hum and common mode distortion/damage. A low frequency hum could cause the clipping.
It would be a good idea to get a sound meter to check the sound level. You should be able to reach 85 Db from this system without clipping. If you need more than that, you MAY need more speakers if the band instruments are too loud. Also if the band has amps that get into the vocal microphones that adds to the clipping level... make sure the mics don't "hear" the band instruments. Make sure your speakers are toward the audience from the mics to avoid the supersonic feedback problem. If the vocalists can't hear themselves with that configuration you need to set up seperate stage monitors.
There are some pretty good videos on YouTube about proper mixer level setup.
Jan 30, 2011 | Behringer Xenyx X2442USB / Harbinger...
Can i connect the pv 112 to the pv 118 subwoofer since the powered mixer i bought it only has 2 main outputs? The powered mixer I bought is the PV XR 8600D powered mixer...
Generally speaking you should only send low frequencies to subs. The highs, while lower in power than the lows, will over time harm the voice coils. The ideal way to do this is to use an external crossover netween the main output and the amp input with the higher range going to a general set of speakers. Send the lows through the second channel of the amp and then to the subs.
In short, while not recommended, yes you can hook them up in parallel.
Dan
Dec 09, 2010 | Peavey Pv118 1x18" Subwoofer Speaker...
I just both the Europower pmp6000 powerd mixer and Eurolive b215xl speakers and i need help conecting the speaker to the mixer. I will be using it with some mics at a function in an hotel. How do I connect...
use 1/4 inch speaker cables. hook one speaker up to "main 1 R" out and the other to "main 1 L" out. if you have additional main speakers, hook them up the the "main 2" outputs.
look for the "bridge amp mode" switch and move it to the "main L- main R" position.
Nov 06, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Can i hook up a seperate power amp . to the pmp 6000 powerd mixer . for more over all power.
You can add extra amps driving ADDITIONAL speakers... you CANNOT parallel amps driving the same speakers.
Drive these seperate amps from the MAINS OUT connnectors using TRS and balanced lines to those external amps.
Aug 19, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Mackie 1604 Vlz3 16 Channel Mixer Logo
62 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
 Grubhead
Grubhead
Joaquim Martins
Are you a Mackie Music Expert? Answer questions, earn points and help others
