Washing Machines Logo
Sam Schmel Posted on May 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lid Sensing light flashing on maytag centennial washer wont start
Was kept on hold or 24 hours
Josh Whitehead
Level 3:
Genius:
  • Master 1,148 Answers
  • Posted on May 23, 2016
Josh Whitehead
Master
Level 3:
Genius:
Answers
1148
Questions
Helped
247238
Points
3024
Could be the sensor has gone bad..but try unplugging for little while then reconnect it..it may reset ..good luck...also try Maytag help and support online..customer services
Maytag Cent. Washer MVWC400XW3, stuck on SENSING and LID LOCK I replaced the Door Lock and Actuator - still getting the same results as I did before I made any replacments
Unfortunately that error code is for a stuck keypad. It's like the button is being held down constantly. You can replace the control panel or clear error codes and try again, also you need to calibrate this washer after changing parts. If you open the lid and reach between the tub and cabinet at the front left corner, you will find the tech manual.
After pushing start, lid locking light flashes, clicks like it is locking but is not locked and nothing happens but it keeps clicking
Sounds like the lid lock itself is bad, be sure to check the connections at the control board. There should be a tech sheet inside the front panel towards the top left. This can help you check the error codes and wiring diagrams.
Maytag centennial washer
When lid lock flashes, that is an indication of a bad lid lock in some of the mvw washers.(depending on your unit and model number &error codes)
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Washer won't start and lid won't lock . it keeps clicking and the sensing light keeps flashing
Thank you janesstone ive been looking for 2 hours trying to figure out that simple wire bypass i just couldnt find what wires did what. Your my hero for the day lol. Everyone should be able to find this answer easier just sayin
16helpful
3answers
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
