check for bulging capacitors on the power supply board. you will have to remove the back cover from the television set to get a good look at the power board. If you do notice swollen capacitors, desolder the bad ones out and solder new ones in.
It sounds that the fault should be with its main digital board. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts. Try and determine whether you can repair it by yourself.
Power supply is in need of repair. Pull out the power supply. You will find transformer (has blue tape). The location of this transformer is T701. Underside of this transformer, pin # EL41 is in need of a resolder.With a small screwdriver, scratch an area next and around this pin. With a hot soldering iron and solder...resolder this pin. Your TV will be fine. There are no capacitors to replace. This is one of the best power supplies built for Philips TVs. Thanks for asking, Matt of Martins TV.
you are not out of luck..all need is a tech to look at your tv...maybe you have partially damage the output chip that is inside the tv...but if you think that doing a repair is too expensive then you must invest in a new set.good luck.
when you unzip the file you may need to put it into a file called "upgrades". Try an empty USB stick (size should not matter) and put the autorun file into the upgrades file.
Hold a flash light to the screen after it goes off and see if you can see a faint picture. Sounds like your backlight might be cutting off. Repair can be expensive but some of the newer units don't require the entire LCD to be replaced.
