Replace your polygon mirror motor or complete laser unit if you have one available. Replace this a.s.a.p as it can cause your BICU to pop. If your machine is already dead and you picked the code up on the web browser you need to replace the BICU as well. Do not replace the BICU without replacing the polygon motor. If you do you will pop the BICU again.
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
