Firmware can only be downloaded by someone with "My Ricoh" access. If you have the Firmware or you are able to get it, just create a "romdata" folder on a SD card and dump the .fwu file in the "romdata" folder. Switch your machine off and insert the SD card into slot 2 on the machine controller. Start machine up and select the firmware you want to update. Machine will reboot when its done. If it doesn't than switch the machine off and remove the SD card and power machine up again. Now you are done.
