Your 081 error refers to the Maintenance board. It is a writing error. You cant fix this but just replace the Maintenance board.
Find an OKI dealer. The part number for the board is 44894903.
Good luck.
An E9 error occurs when the printer detects that ink system maintenance is required. An Ink System Maintenance page prints containing instructions to open and close the printhead access door to resolve the error.
Three digit remote codes for Mitsubishi are: 004/ 005/ 009/ 022/ 046/ 081/ 089/ 132/ 133/ 180 Four digit codes are: 0005 0151 0051 0004 0009 0254 0022 0141 0180 Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
Hello Three digit codes for Mitsubishi are: 004/ 005/ 009/ 022/ 046/ 081/ 089/ 132/ 133/ 180 Four digit codes are: 0005 0151 0051 0004 0009 0254 0022 0141 0180
Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
according to the troubleshooting guide
Examples of Error Messages
The following are examples of error messages.
<S00-000>
Service Calls
These error messages are displayed when inspection or repair is required by a service representative.
That is a network or connection problem Has anything changed set up wise ckeck that you have the right driver installed.and check that the physicsl connection is correct
Download the PowerISO file and Install. Once the system reboots, go to My computer. Now you can see a new CD Drive. Right Click on it and select PowerISO-> Mount image to Drive. Now browse option will open and select the disc Image file and click open.
After that Right Click on the New Cd Drive and click on open and the setup will run...
10.0002 Magenta cartridge e-label errorError message
10.0002 supply error
alternates with
Reinstall with a ? under the Magenta print cartridge gas gauge
Description
E-label cannot be read or print cartridge is not properly installed.
Action
Open the front cover of printer and remove the toner cartridge exhibiting error.
Inspect the print cartridge to ensure the e-label reader is attached to print cartridge and is not damaged.
Inspect the inside of printer to verify the e-label does not have any product packing tape still attached.
Inspect the e-label reader to ensure the gold contact points are not damaged or bent. Also inspect the black plastic on e-label reader to ensure it is not bent or broken.
Reinstall the print cartridge.
Power cycle the device.
If reinstalling the print cartridge does not resolve the issue, replace the print cartridge.
If the problem continues, contact HP Customer Support Center for technical assistance
Explanation
A 924.xx error message indicates that an "open circuit" has been detected in the fuser unit. What to do
If this is the first time you have seen the error, turn the printer off.
Leave the printer off for at least 10 seconds to give it a chance to reset, then turn it back on.
If this does not clear the fuser error, the printer will probably require service. The parts most likely to be causing this error are the following: 1st, the fuser unit ( this is the most likely of the three ) 2nd, the system board 3rd, the low voltage power supplyunit.
These parts will need to be inspected by a service technician and replaced as necessary. IMPORTANT! If this is an intermittent error, you may want to check how the printer is plugged into the wall. Make sure it is plugged straight into the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in the printer which can trigger a false fuser error. This is true even if the printer has worked on this surge device previously.
