Some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
SOURCE: SC 548 on ricoh aficio 2022
Hi Andreas: The fusing unit has not been reinstalled properly. There is a receptical on the back of the Fuser that mates with a plug in the machine when you install the part. the machine is telling you it did not detect the fuser. Undo the screws and remove it and reinset it again, makin sure that it seats properly. then you will need to reset the code. Go into SP Mode: Push in sequence; Clear-107-red stop button(hold this down until display changes and shows "copy etc"), turn machine off(using red power switch, wait 10seconds and turn back on. If you still get the error code the fuser still is not inserted correctly. Hope this helps.
PS: Black spots can also indicate a new drum is needed. It may have a small chip in the surface.
Regards
Munybuny
SOURCE: canon ir 2022 digital copier error code E001
how many blinks do you see in the led indicator? if it is 5 blinks then the problem is the printhead. if it is 2 blinks, then problem is in the feeding mechanism. if the problem is the later, then you might have to bring the unit to an authorize service center to have it checked.
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
SOURCE: error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
SOURCE: Won't receive all pages of a fax. Generating service codes 00-83
That could be caused by a number of things:
Are you connected to the phone line by a very long telephone cable? This can cause extra interference and cause these codes. Or it could be a deteriorated cable...try another one.
otherwise, it could be a fax circuit board problem, but more likely you need to have the 'cable equalizer " adjustment performed in "service mode", which is a fairly simple adjustment for a service tech, but too complicated to explain here.
I hope this helps.
