Apple - iPad Air 2 Wi-Fi 64GB Logo
A
Anonymous Posted on May 26, 2016
I entered the wrong email address to access my iCloud account and need to know how to change it.
I miss typed my email address and cannot access my account to correct the problem. How can I Change the email address?
Stephen Riw
Level 2:
Habit-Forming:
Scholar:
  • Expert 47 Answers
  • Posted on May 26, 2017
Stephen Riw
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
47
Questions
0
Helped
28932
Points
182
Changing iCloud email equals to changing Apple ID, steps are:
Step 1. Go to http://appleid.apple.com > Sign in your Apple ID > When you enter the account managing page, click Edit on the right, next to REACHABLE AT.
Step 2. Click Change Apple ID > There will be a box where you need to enter the new email address > Click Continue button > Then a six-figure code is needed to continue. Apple will send an email with six-figure verification code to your new address, and go to the new email address to get the verification code.
Step 3. Enter the six-figure code > Click Continue > Click Done, and your iCloud email is successfully changed.
robert
Level 3:
  • Apple Master 2,548 Answers
  • Posted on May 26, 2016
robert
Apple Master
Level 3:
Answers
2548
Questions
0
Helped
870407
Points
8043
Your original email address is your iCloud acct email, unless you changed the acct info. if you just mistyped, then retype because you could not get into a mistyped email address and get in. or is it a locked acct your are trying to break into?
2answers
I want to remove icloud activation from my ipad
Steps to delete iCloud account on iPhone/iPad
  1. Tap on the Settings app and then scroll down to find iCloud.
  2. Tap on "iCloud" to open it.
  3. Scroll down until you find "Delete Account" and then tap on that.
  4. Tap on "Delete" again to confirm the deletion of the iCloud account.
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
2answers
Change iCloud email address
If you need to change the iCloud account or Apple ID account on your iPhone, you must delete the existing iCloud account on the device. How to Change iCloud Email on an iPhone
My ipad is saying apple id disabled,how do I get it un disabled?
How To Resolve The Apple ID Locked Or Disabled Issue?
Well, if someone unfortunately tries to hack into the user's Apple account by entering the password incorrectly infinite times, or even giving various wrong answers to your security questions, Apple will further easily recognize the attack and will entirely lock your Apple ID. As researched by Mac technical support team, it's a good sign because it signifies that an attacker can't anyway gain access to the user's Apple ID to avoid allowing them get into a user's iCloud email, iMessages as well as FaceTime. However, it may often happen that it's not a hacker who is trying to get access to your account, sometimes it's only we who is getting ourself locked out of the account because we have forgotten the password.
Solutions to resolve the "Apple ID Locked Or Disabled Issue.
Solution1: Unlock the Apple ID Whatever the reason for Apple's disabling the account is, there is every possibility to get back into it. One simply needs to follow all these below mentioned tricks to recover their account and create a new password.
  • Go to the iforgot.apple.com section
  • Enter the Apple ID which will usually be the email address associated with the user's Apple account.
  • A professional team of Mac tech support experts have suggested to enter the Code to prove that a particular user isn't a robot.
  • Click on the "Continue" button
Solution2: This phase is based on the security process
·If you are working with the set up two-factor authentication then it is quite possible for users to receive a code on a trusted device or as a text message on the phone. Users are required to enter the verification code before unlocking their account and changing the password.
·If anyone is working with older two-step verification process, then a recovery key is needed that was sent to them while setting up two-step verification process in addition to a code sent to a trusted device.
·Well, if a user haven't set up either of the above methods for security purposes then one needs to unlock the account by using their password, or simply has to answer few provided security questions at the some point.
Fix your Mac issues with expert team working at Mac customer support Toll-Free 1-800-213-8289 department and get all your headache resolved at a go.
1helpful
2answers
How can I resset my iCloud? I put a wrong email so now it won't verify my account
You can always restore it to brand new.
You need a computer with iTunes and the charghing usb cable.
Before restoring make sure that the Find my iPhone app is off, otherwise after restoring it will give you the very same wrong email.
Once that is off, connect the ipad to the computer and click restore.
Once restore is complete, at very end you will be prompt with 2 questions:
1. Set iPad as brand new
2. Restore from (your name) back up.
At this iem you can choose either one, because Find my iPhone is off. And now you can change the email address.
It is your best option since it is way too difficult without restoring it.
How can I aCcess my icloud email when I cannot remember password
You can go to iCloud.com and ask to have your password reset. You however must know what email account you used when you registered. iCloud will send you a link to your registered email account, follow the link and reset your password. Write it down somewhere.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
