Tv screen is blur when switched on
SOURCE: JVC I ART
Funny sounds tend to lead to a short of one or more componets most likely the HOT and FBT I also would not rule out the convergance IC's. this repair should be left to the repair gods.
SOURCE: Tv turns off by it self
This usually is heat related. Is the filter clean? The fan working? Otherwise there is most likly a "so called" cold solder joint...where the connection on a board is not positively made...often when it warms up the joint will 'open'..disconnect. This needs re-soldering.
SOURCE: Blurred TV - double vision with red hue
I was searching online about what could be the problem with our TV and I came across your page. We have a 52" JVC Projection TV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur.
If you have any suggestions on what caused this and what we can do to have this fixed, I would greatly appreciate your advice.
SOURCE: jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
