Washing Machines Logo
A
Anonymous Posted on May 26, 2016
I HAVE A WHIRLPOOL TOP LOADER MODEL 3LSR6253E01 MY WASHING COMES OUT COVERED IN LINT. I CANT FIND A FILTER ON THE MACHINE IS THERE ONE? PLEASE HELP THANKS KATE
SERIAL NUMBER CJ4124663
I HAVE A WHIRLPOOL FRONT LOADER MODEL 3LSR6253E01 MY WASHING COMES OUT COVERED IN LINT. I CANT FIND A FILTER ON THE MACHINE IS THERE ONE? PLEASE HELP THANKS KATE
No, there is no filter- but you should check the drain pump trap for a mass of fibers/lint. Usually, there is a service door on the lower front of the machine that leads to the pump... Have some towels ready for residual water, but I would check there first...
Where do I find the filter on a Whirlpool top loader - our clothes regularly need re-washing as are covered in fluff?
have you check the outlet drain hose for blockage? go online check your wp model for built-in filter if any. if there is one you need the washmachine schematic show the location of the filter. most of the old machine may have a panel on the backside to access. this way you can get to the filter.
Hi I have a Maytag Atlantis MAV975OA top loader. I cannot find a lint filter anywhere and my washing is coming out covered in lint. Can you tell me where the lint filter is so I can clean it? Thankyou
Hi gmallard, it doesn't have a lint collector. This machine is a piece of junk. We're going out today to buy a new one after years of brushing down our clothes with lint brushes. I'll put the Maytag in the shed to wash my dogs pillows etc. (about all it's good for)
I have a Simpson EZI Loader 5.5kg, where is the lint filter
HI just read your posting.Now the SIMPSON EZI LOADER comes in front and top loader versions.Which type is yours?Are you getting a lot of lint on your clothes?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
2helpful
Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Clothes covered in lint
You need a new timer. Reducing the cycle time will help the lint and not having a timer stuck on wash will help too.
Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
4helpful
3answers
Washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
