SOURCE: stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
SOURCE: I have a GE WCVH6800JMS
Hello, Welcome to FixYa. Based on the symptom you've described ( wont spin proper on any cycle ) the first thing I would do is to remove the lower panel and check the pump filter for blockages/debris. Believe or not, that is enough to prevent those GE washers ( as is the case with any washer ) from spinning and is a very common problem. **UNPLUG THE WASHER BEFORE SERVICING...Safety first** If you've never done it before you need only remove the screws at the very bottom and the access panel will pull away exposing the pump with a filter which screws out. Once to that point, unscrew it slowly as to let any water out gradually ( a wet-dry shop vacuum is handy here to **** up the water...or plenty of towels ) and then check inside the pump thoroughly as well for and debris which can cause slow draining thus preventing a good quality hi-speed spin/water extraction. If any of this is not clear I could send you a service manual via a pdf attachment through email, but obviously you'd have to post an email address first. Let me know how you make out and we'll go from there. Good luck. Regards, Macmarkus :)
