Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
The tv will turn off after two or three days of using it. And in the back of the tv the spdif light is on. spdif is out.
Tv just turns off after two or three days of using it
    Top Expert:
  • Westinghouse Master
  • 76,171 Answers
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on May 29, 2016
6ya staff
SOURCE:
How do I connect hw-h450 wireless soundbar to 40h5003af samsung tv?
Really depends on what you're switching. If you plan on using a DVD, Cable/Satellite receiver, or more than you'll want to plug all those sources into the HDMI inputs of the TV. From the TV you'll want to run an SPdiF cable to the back of the sound bar. These cables can be had for less than $6 on Amazon unless you have one already. This is the simplest and cleanest way to use the soundbar as the TV's speakers. Go to MENU on the TV and select AUDIO and then turn off the TV's speakers. This will enable the SPdiF output to the soundbar.
Feb 21, 2015 | Samsung Audio Players & Recorders
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Wont turn on
Hi
With the back removed from the Tv look at the power supply for swollen or bulged capacitors on top, they may even leak a brown like liquid substance from them and are usually valued around 1000uf / 10v.
This is a common fault of these power supplys, any you suspect change with a higher voltage but always keep the same uf.
Lets say 1000uf / 25v
Hope this helps.
Apr 09, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
T.v turns off about 3 times a day
Its problem of bulb that got weak in result and causing TV shut down.
Replace bulb in TV and I would recommend to buy Sony original bulb for TV safety.
Jul 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Toshiba 32D46 - White Lines at Top Of Display and TV Not Turning
Ok, so know you own an LCD or Plazma set, visit the dumpster where your Toshiba is or perhaps your basement just for old times sake..
May 30, 2009 | Toshiba 32D46 32" TV
Sony kv-32hs500
Most probably the IC504 (Sharp PQ05RD21) on A-Board went bad. This model TV, including mine, is notorious for having this problem. The IC is rather easy to find and inexpensive (around $2.50). Your main problem will be desoldering the old one and soldering the new one.
Good Luck.
Jul 25, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
SPDIF Output
SPDIF output is only for the integrated digital tuner.
Jan 23, 2008 | Philips 37PF5521D 37 in. HD-Ready LCD...
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
