Question about Toshiba Tablets & eReaders
How to unstuck the on and off button on my Toshiba 7"tablet
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
Try Cleaning button with q-tip swap and 92% Isopurple alcohol. Try dry air first.
Posted on May 30, 2016
  • Anonymous Aug 20, 2016
    Thank you it worked kudos to you
6ya staff
SOURCE:
How do I turn off safe mode my kindle fire
Safe mode means that problem has occurred when the tablet tried to "Boot" on. You must find and fix whatever that problem is to go out of safe mode.
Apr 08, 2017 | Tablets & eReaders
My toshiba excite 10 wont let me connect to my WI-FI what to do please
Check your router, leave the tablet the way it is. If you have a modern router it have the capability to change channels (from 2.4 to 5gh.) Also try to test the tablet with other wireless services, like from a friend or your phone hot spot. If it connects, then it's most definitively your router.
Feb 04, 2015 | Toshiba Tablets & eReaders
My toshiba excite 16gb 10 hd sku:7360TT2 it wont let me connect to wi-fi what can i do i factory reset nd nothing
The solution is a factory reset....I know you mentioned you have done this but did you follow this method?
1.Make sure the tablet is off and not in standby.
2.Hold down the 'Volume Up' and 'Power' buttons simultaneously until the two Android icons appear.
3.Use the volume buttons to select the white box on the right.
4.Once selected, press the power button.
5.Use the volume buttons to select 'wipe cache partition' and then press the power button.
6.Select 'Yes' and press the power button.
7.Use the volume buttons to select 'wipe data/factory reset' and then press the power button.
8.Select 'Yes' and press the power button.
9.The tablet will now reset.
How can i fix my toshiba excite 10 tablet doesnt want to connect to my wi-fi it doesnt let me add a network or scan either please help me
The solution is a factory reset....I know you have done this but did you follow these instructions?
My toshiba tablet wont connect to my wi-fi please help
1. Make sure that your wi-fi settings are turned on.
2. Scan for local wi-fi
3. Select your desired wi-fi and provide password if required.
Many times, the settings from the menu are not turned on, so the tablet will not try to link to a wi-fi site.
If you need more help, please provide the model number and the operating system currently being used on the tablet.
Do not have the pin to unlock my toshiba excite 10 tablet what is the code
Factory reset is the only answer;
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset.
Jan 08, 2018 | Toshiba Tablet. Excite 10.1 in. Android...
My Polaroid 4.3 Internet Tablet power button broke, is there any other way to turn it on?
Sometimes, if you plug in the power cord, a tablet will turn on automatically. If that doesn't work, the button will either need to be replaced, or you will need to get another tablet. A lot of the cheaper tablets like Polaroid, Coby, and the like are made to be throwaway devices. Once they break, it's more cost-efficient to just buy a new one a lot of the time.
Jan 02, 2013 | Polaroid 4.3" Internet Tablet
My laptop "toshiba tablet portage
If your computer is still under warranty you can contact the Toshiba support site and order recovery media. They will refer you to the company that sells them. The cost is about 45 dollars + taxes.
Even if your computer is no longer under warranty you may still be able to obtain the recovery medias.
Failing that, you may consider buying a retail version of the Windows Operating system and install it on the computer. Some custom buttons may not work, and you will have to go to the Toshiba support web site to download the drivers for your computer. Before buying a version of Windows, check the Toshiba site for your computer and your intented OS (WinXP 32/64, Vista 32/64, or Win 7 32/64) )to see if they have drivers.
May 20, 2011 | Toshiba Portege 3500 Tablet PC
I installed windows xp on my toshiba tecra m4. How stylus pen works?
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
CreativeTECH
Apr 23, 2011 | Toshiba Tecra M4-S435 Tablet PC
Audio driver toshiba portege 3500
Go to the Toshiba website and download the updated drivers for your system. They are free.
Oct 14, 2009 | Toshiba Portege 3500 Tablet PC
Tablets & eReaders Logo
57 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Ekse
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
