SOURCE: My phillips model # 50P8341
the set is going into shutdown mode. does the power indicator blink when it shuts down. If so how n=many blinks does it blink?
SOURCE: RED LIGHT FLASHES AND TV TURNS ON AND OFF
Contact the company that makes your tv and find out what the "code" (# of times the red light flashes) means. Then call a repair place and check prices on the part. It might be worth having them fix it for you! My tv is a phillips 50" plasma and the light was flashing 6 times witch ment "power board" the part was 318 and the labor was 195....for a tv I paid 2,000 for 23 months ago. I hope it doesnt go out in another 2 years....nice that they know it will go out and even program a "code" in it for you!!!
SOURCE: I HAVE A PHILLIPS MODEL
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from partstore.com and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
SOURCE: My friend has a Phillips RPTV model number 50P8341
install the convergence repair kit. Its takes 2 STK392-110 Convergence ICs and you will need a few of the 6.8 ohm resistors. You can get the DPTV305 -DPTV345 convergence repair kit which also applies to your model from www.tvrepairworld.com which has the parts and the CD with instructions and the Kit has the STK392-120 ICs which would be a better set of ICs for your model.
SOURCE: Phillips 50P8341 will stay on
Seems like it is overheating. Try cooling it down by using a fan to blow air into it (temporary fix). Make sure the TV is well ventilated and heat can escape (permanent solution).
