Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
SOURCE: Universal remote codes for Philco digital to analog converter box
http://www.remotecodelist.com/remotes/
SOURCE: codes for my sons TV
Hi there i also had this problem with my "onn" television and there isnt an "onn" make - apparantly it is the same as pacific or schneider so if you get a remote from asda theyre really cheap less than a tenner - i found that look up either schneider or pacific and the first code it says should work for your tv!hope this helps!
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable. The Installation Guide should appear. The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
SOURCE: Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
SOURCE: NEED CODE FOR AN APEX CONVERTER BOX FOR THE RCA
how can i program a rca remote without a code search button to a apex digital converter cable box
