Question about Stihl Garden
Stihl fs46 trimmer the clutch drum turns till piston is all the way up and stops then turns back the other way till piston is down then stops. Is this normal or not
  • Stihl Master
  • 1,807 Answers
Not normal
Posted on Jun 09, 2016
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 157 Answers
SOURCE: Stihl line trimmer FS46 Runs good at full throtle
the smallest piece of trash will cause you the biggest problems. try blowing the carb out . i think it has a pre set idle on it.
Posted on Sep 19, 2009
nova2nv
Bill Linda Rivard
  • 197 Answers
SOURCE: Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Posted on Nov 28, 2009
How to remove clutch from Stihl fs81 brushcutter?
go google and type in --workshop manual for Stihl brush cutter model fs 81 -- and download the pdf version from the stihl site
Feb 08, 2016 | Stihl Garden
Bosch spark plug gap for a fs46 weeteater
Hi
Stihl recommend 0.020 (20 thousands of an inch) or 0.5 mm. Incidentally the plug gap is independent of the plug make.
Regards
Jacko from down under
Aug 15, 2014 | Stihl Km 38 45 46 55 Trimmer Clutch Drum
Trimmer head won't rotate
Usually this is a clutch problem, the clutch is under the drum and when it engages turns the drum which turns the drive shaft which turns the trimmer head. If the drum is not turning than it is the clutch, if the clutch is turning the drive shaft could be broke, if the drive shaft is not broke than the problem would be in the gears of the trimmer head.
Apr 11, 2014 | Stihl FS 85 Weed Eater
Cultivator spinning slow
If the blades are turning slowly while the machine is on tick-over, then it is more than likely a clutch issue. Clutch springs will stretch and occasionally break. With less resistance on the clutch shoes they grip the clutch drum and this in-turn will cause the blades to turn.
Check clutch springs.
Apr 10, 2013 | Stihl Garden
How do you change the clutch?
Remove the side casing. (bar side)
Take off bar and chain.
Remove E-clip holding the clutch drum on.
Remove clutch drum and needle cage bearing.
This should expose the clutch.
Remove spark plug.
Use a piston stop to stop the piston rising, Sometimes a knotted piece of pull cord fed into the cylinder is just as good.
Turn the clutch clockwise with a socket to unscrew.
To put clutch back on turn anticlockwise till piston cycles back and hits the piston stop again and tighten. Replace spark plug and clutch drum, bearing, bar and chain and side casing.
Mar 15, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How to remove the clutch assembly on a stihl 015 AV
Remove spark plug.
Use a piston block to stop the piston rising.
Remove the chain sproclet cover.
Turn the clutch with a socket clockwise to undo.
Dec 11, 2012 | Stihl Chainsaw Hedge Trimmer Clutch 015 Av...
STIHL FC 90
needle nose pliers and a lot of patience.. best to disconect the fuel lines from the carb, remove the tank and remove the fuel line and gromit from the tank. filter come out with it. replace it then work in reverse till its back together.
Aug 11, 2012 | Stihl Fc, 36, 40, 44 Trimmer Edger Clutch...
Oil pump on 020 stihl
Remove the side casing,then remove the spark plug and use a piston block to stop the piston rising while you remobe the clutch, once the clutch is off, the drum, bearing and oil work should be removable,along with the 2 plastic crank coveres. Once all this has been taken off you will have access to the oil pump.
Apr 28, 2012 | Stihl 020av 020 Av Chainsaw Oil Pump...
Nov 27, 2009 | Garden
Sep 18, 2009 | Garden
Garden Logo
217 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Joe Paxton
Level 1 Expert
ray gallant
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
