Acquired through a donation and the original owner does not know the admin setup password. We are unable to get into admin mode to reset the settings so it can make copies and scan. The mode is currently stuck on "Scan". When I press the copy button it says "not available". I'm able to get into the Tech Menu by pressing Menu # 1934, however, I do not see factory reset in the menu. Does anyone have a fix for this?
SOURCE: Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
SOURCE: Samsung SCX-4725FN - why won't it scan
You have to scan through your computer printers/scanners area. I had this problem, too, but that seemed to fix it for me.
SOURCE: Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170
2. Right-click/properties - Compatibility tab.
3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
SOURCE: i have a dvdvr375 that needs factory reset. How?
Try unplug,replug the unit back an hour later,should have everythings,reset to Factory setting.If no,electronic component's parts burn in ur device.
