Wiring diagram
Russell if you truly want to figure out this problem you need to look at the wires and ware they connect .And what they connect to then drew your own wiring diagram its not that difficult if you break down and do a few tests with an OHM meter to see what is connected and what happens when you through a switch or run a jumper wire to a ground .
If you think about its not really that complex .
