Washing machine will wash but wont pump water out at the end off wash,but you can here a clicking noise from the back off the machine ,sounds like a solinoid of some type,i can blow through the outlet hose back into the machine,so its not blocked.
If your Maytag washing machine is making a loud noise during the spin cycle and is not draining the water, there are a few possible causes. Here are some steps you can take to troubleshoot the problem:
Check the drain hose: Make sure the drain hose is not clogged or kinked. If the hose is clogged or kinked, water may not be able to drain properly.
Check the pump: The pump is responsible for draining the water from the washing machine. If the pump is not working properly, it may be making a loud noise and not draining the water. You can check the pump by removing the front panel of the washing machine and locating the pump. Check for any visible damage or obstructions.
Check the belt: The belt is responsible for turning the pump. If the belt is worn or broken, the pump may not be able to drain the water properly. You can check the belt by removing the back panel of the washing machine and inspecting the belt.
Check the bearings: The bearings are located in the drum of the washing machine and can wear out over time, causing a loud noise during the spin cycle. If the bearings are worn out, they will need to be replaced.
If you are not comfortable troubleshooting the problem yourself, you may want to contact a professional appliance repair service for
It is very unusual for a front loader, it does have both a recirculation pump and a drain pump! I don't see any diverter valves. Exploded parts diagram.
It is a common fault that the drain fails to work in
most machines in a period of time and is the most problematic fault in a
washing machine. In all occasions it is important that your observation is most
important and so is vital to the identification /rectification and solution. If
you have noticed that water has leaked then as the drain hose pump/valve and
fittings are located on the underside of the machine it is important that you
look for possible leaks here. In some cases the drain hose would be clogged at
the drain end to outlet of the house and so there will be back flushing
resulting in overflow to the outside. Also the drain pump/valve can be clogged.
Now remove the drain hose clamps and remove the drain pump/valve, clean the
drain pump/valve, use back flushing to clear off all dirt. Now test using power
to see if this works and can be simulated. When refitting, the hose must be tightened
properly. If the pump/valve does not work even with power then it must be
replaced. If there is intermittent power
to the drain valve/pump then the program controller unit is a suspect.
Finally the washer must be placed with a tilt- use a
spirit level- so that all water will drain to the outlet port and thereby there
is no residual water remaining.
Replacing the pump on a Bosch machine, please check
this link for tips:
this link for tips:
It is a common fault that the drain fails to work inmost machines in a period of time and is the most problematic fault in awashing machine. In all occasions it is important that your observation is mostimportant and so is vital to the identification /rectification and solution. Ifyou have noticed that water has leaked then as the drain hose pump/valve andfittings are located on the underside of the machine it is important that youlook for possible leaks here. In some cases the drain hose would be clogged atthe drain end to outlet of the house and so there will be back flushingresulting in overflow to the outside. Also the drain pump/valve can be clogged.Now remove the drain hose clamps and remove the drain pump/valve, clean thedrain pump/valve, use back flushing to clear off all dirt. Now test using powerto see if this works and can be simulated. When refitting, the hose must be tightenedproperly. If the pump/valve does not work even with power then it must bereplaced. If there is intermittent powerto the drain valve/pump then the program controller unit is a suspect.Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use aspirit level- so that all water will drain to the outlet port and thereby thereis no residual water remaining. Replacing the pump on a Bosch machine, please checkthis link for tips:http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
