I recently upgraded to windows 10 about a month ago. Tonight I decided to copy my files to onedrive, in the process I accidentally moved them from my documents on my C drive to onedrive. In doing so, I have lost parts of what I have transferred, The file appears but has no contents, also the files cannot be found using search everything on onedrive and also cannot be found on my computer (C drive). help would be greatly appreciated, Thanks!
SOURCE: how locate and transfer job registration tool data for new installation
There are 2 methods:
1) On the existing PC, start the Job registration tool, click the "Administrators" button (on the bottom of the dialog), then click the "Backup" button in the dialog that appears. This will save a registry file that you can then transfer to the new PC.
2) Use regedit to browse to the
HKEY_CURRENT_USER\SOFTWARE\Canon Electronics Inc.\DR-1210C-JobTool
branch. Save this branch to a file, then transfer it to the new PC.
Cheers!
SOURCE: windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
thankyou for using fixya
dont forget to rate the solution
have a nice day
SOURCE: Cannot copy files to "My memory" card
Hi there, l am going to try and show you how to get to your memory card step by step starting with one
1...connect your phone to your putter
2...click on explore in the Microsoft ActivSync box when it is finished synchronized
3...another window will pop up that is called Mobile Device
4...at the very top of the list Double click on...My Windows Mobile Device
5...in the next widow click on...My Storage
6...OK if you did everything the way l have told you...you are half way there
7...now what you do here is right click and make a new folder and call it.. Video or Music or Photo's
8...The rest is easy just open that folder and copy and paste what ever you want into it....
9...Like me, l made a folder for photo's and music and video's..make as many as you want
10...When you finish putting in all your music and video's and photo's into your folder's.. close everything and disconnect your phone from your putter
11...Now gab your phone and go click on Menu
12...then click on media album
13...then click on My Storage
14...there you go...all the folder's you made are there, just click on them to open them but remember if you click on your music folder make sure that you highlight the music note at the bottom of your phone screen or the file's will not show they are there...
15...The same is for video's and photo's, make sure you click the right image to what you want to view in that folder at the bottom of your phone......
16...To play a song or to view anything just click on it....
17...Well l hope l have solved everything for you, if you got this far down, good luck and all the best
SOURCE: Windows Failed to load because Kernel file is missing, or corrupt
Are you talking about two problems on one computer? If so, the first problem doesn't matter until the second one is fixed. If you are talking about two different computers, then the problems can be each addressed.
For the hard drive that is not recognized, where did it come from? If you purchased it used, you may be out of luck. It sounds like you have a pretty good idea how computers work, and it also sounds like this hard drive does not work at all.
If these are both the same computer, then replacing the hard drive with a known working hard drive will most likely provide you with a solution.
I wish I had better news for you.
try pressing f8 when you load vista and then select start normally
if that doest not work and gives you the same error then restart and press F12 as soon as you see the dell logo, put in the vista installation disk that you got with the laptop and select boot with disk option.
try and repair or the recovery option .
NOTE : IT IS RECOMMENDED TO TAKE BACK UP OF YOUR FILES BEFORE USING THE RECOVERY OPTION .
