The radio will not play every since we changed the battery in the car. Changed all fuses, nothing. Removed the radio now want to determine if the problem is the radio or the car? Please help. DNB451.
SOURCE: Becker Car Radio Security Code Unlock
The best way that your gonna find it is by checking out the dealership, they can help you with that
SOURCE: Daewoo Radio Code
You will need to give me a few more details about the gear, and the car. Make, Model, year of manufacture. Then I can help you both :)
SOURCE: radio code for 2002 mitsubishi eclipse spyder needed please!
A bit of info....if you try to enter codes three times, you radio will go to lock...as far as I know, only a dealer can help you with that problem...
SOURCE: Becker Code please
I have same issue, so I called a local dealership. They said sure no problem as long as you have the vin# make model etc. of the original car. Or you have to bring it in to dealer to pull code from radio. Becker charges 20 bucks as well with less info. Good luck
SOURCE: disconnected battery I just bought the car and no radio code
You need to recover the radio's serial number to decode the 4 digit radio key. The full process and decoder is available here: Porsche Boxster: Online Lost Radio Code Recovery Tool
