The program you are playing back works ok for about 15 minutes then the picture freezes.
SOURCE: Player freezes at same time on almost every disk, and recorder programs won't play on anything else.
The last problem is probably because you have not ?finalized? the DVD yet. Basically what that does is modify how the data is stored on the DVD so that a normal DVD player can read it. It also prevents you from modifying or recording to the disk any more so make sure you?re done before performing this. The part about the freezing is more complex, are these commercially recorded DVDs or something someone else recorded?
SOURCE: freeze
Seen those cable cards get corrupted, take out the card and run straight cable and see what happens
SOURCE: Several problems
you may want to check all of your coax conections and stray ground shield piece littl tiny silver mtal wire will cause that reaction or you may have a ad reciever if so if ou have the directv inurance they will replace it for no cost to you at all.
good luck
please rate
SOURCE: EyeTV Freeze
I have had the same issue and it went away after cleaning out my almost full hard drive.
