Electrical Supplies Logo
d
diane Posted on Jun 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
King craft 1705 generator produces no power out put
No power output
TStevens
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 110 Answers
  • Posted on Aug 03, 2016
TStevens
Expert
Level 2:
New Friend:
Cheetah:
Answers
110
Questions
0
Helped
51540
Points
330
May have condinsation around the winding inside. Shut it off, try again (may have been a fluke)
I have a kings craft and it want start it is the 1705 and I've had it for 3yrs andused it 1 time help me.
What would you like to know?
Fill oil to the top, add unleaded fuel, and pull the recoil to turn over engine 3 times. This should prime the carb. Then start!
If it is still not starting, please contact us. We are always happy to talk you through it.
https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
Why isn't it producing rated output?
Rated output is at full load. Units will produce power up to that limit and use gas accordingly. Very lite load = less output and less gas consumption, etc.
Why is king craft 2200 generator govonor not working
Are you talking about idle switch or the primary running speed. Had the Gen. been stored for awhile. Check for free movement of linkages to Carburetor.
Sigma 6500E generator
First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
High voltage rpm power generator output
Not sure what you mean "high voltage rpm power generator out", however many people have asked how to adjust the engine for proper voltage output. On generators with~out a voltage regulator, I adjust the engine RPM by using a digital voltage meter that has a Hz setting. Adjust the governor untill the meter displays 60 Hz. With the geneator producing 60 cycles, I know that the engine is turning 3600 rpm (the engine produces max hp when it is turning 3600 rpm). At this point, read the voltage output to verify that the range is between 115 ~ 120. On generators with a voltage regulator, verify/adjust that generator is producing 60 cycles then adjust voltage by turning screw at the regulator (some regulators are sealed with potting compound and can not be adjusted). If your power demands are not that great and you appliance can operate at 50 cycles, adjust governor as needed. Lowering to 50 cycles will also reduce output voltage. Good luck
2answers
No output from my generator
check breaker, your outlets should be like a gfi
No output from my lincoln ac welder/generator
Check excitor coils, they produce power from the generator head..
4helpful
Honda generator em 1800
Honda generators are very reliable and are easy to adjust. The best way to check for proper output is to use a meter that can check cycles and voltage. Set meter to htz or freq and adjust the engine governor to 60 cycles. When the engine is turning 3600 rpm it is at max power and the generator may be producing ac voltage ranging from 115 to 125 at 60 cycles. When you draw power from the generator the engine governor will try to overcome the stress and maintain 3600 rpm. The engine must be well maintained to produce full power. Service oil, filter, plug and valve adjustment. Some engines have a spark arrester installed in the muffler that may become blocked with carbon. If engine is producing full power and voltage/amps is low then check brushes, capacitors, and/ or voltage regulator. Most problems occur when too much power is requested from rated generator. Example, trying to connect an 1800 watt air compressor to generator. The compressor may draw double the stated wattage upon starting and cycling. For longest generator life, It is best to use only 75% of rated output. On an 1800 watt generator use max wattage 1350. If you actually need to use 1800 watts then the best generator would be a 2500 watt. enjoy
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
