Toys Logo
Torque settings What is the torque settings and sequence to torque the cylinder head of Massey Ferguson 135 diesel tractor engine
3 Related Answers
relojmesa
  • 84 Answers
  • Posted on Oct 16, 2009
SOURCE: I need to the know the head torque settings on a
I think you may have to contact massey ferguson
Anonymous
  • Posted on Apr 03, 2011
SOURCE: need a wiring diagram for a massey ferguson 135 tractor
I need a wiring diagram for my massey ferguson 135 tractor regards ****
Mike Driver
  • 71 Answers
  • Posted on Dec 05, 2014
SOURCE: what is the main bearing bolts torque.the connecting bearing bolts torque and cylinder head bolts totque for E3CD engine in 1540 massey ferguson tractor
I don't have your answer but if you google torque specs for your engine I'm sure you will find your answer. When I'm not sure I will call a dealer and they will most likely help out with the info
2answers
Whats the cylinder head torque sequence for Captiva 2.0L diesel Z20S1 engine
it always starts from the inside out and only 50% of the torque setting than on the second pass torque down 100%
What is the main bearing bolts torque.the connecting bearing bolts torque and cylinder head bolts totque for E3CD engine in 1540 massey ferguson tractor
Installing a used engine in my boat
This is a random choice for your engine.
You would really need the model and probably the serial to get the correct specs.
The Perkins Model AD3.152 engine used in Massey Ferguson 135 tractors built between 1968 and 1975 had the following torque specs.
45 hp
1211 ft pounds of torque at 1300 RPM
Max RPM was 2000
I need torque settings for 2003 ford ranger 2.5 turbo diesel wlt cylinder head
The torque settings for the cylinder head on a 2003 Ford Ranger 2.5 turbo diesel WLT engine are as follows:
  • Main cap bolts: 70 Nm (52 ft-lbs)
  • Head bolts: 65 Nm (48 ft-lbs)
  • Rocker arm shaft nuts: 25 Nm (18 ft-lbs)
It is important to note that these torque values are for the cylinder head bolts and main cap bolts only. Other fasteners on the engine, such as the oil pan bolts, may have different torque requirements.
It is also important to use a torque wrench and follow the proper tightening sequence when installing the cylinder head. Consult the service manual for your vehicle or a repair manual for the specific tightening sequence and additional torque specifications.
I hope this information is helpful. If you have any further questions or need additional assistance, don't hesitate to ask.
3helpful
3answers
What kind of oil goes in a Massey Ferguson Tractor gearbox?
What model tractor - MF130/135 diesel takes 10/30 not gear oil for transmission/hydraulics
17helpful
Need a wiring diagram for a massey ferguson 135 tractor
Top Diesel Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Diesel Toy Expert? Answer questions, earn points and help others
