The alert light is red and the printer won't print. On the display it says, SC 542. I found instructions on line to help clear this error for the sp 3510 but those instructions can't work for a sp 3510dn because it does not have an online button. I found instructions on how to clear the error on other aficio models by entering the number 107 but sp 3510dn does not have a number key pad.
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
SOURCE: Hi i have problem on my copier model Ricoh aficio
If you've done all of those steps and the problem keeps happening, it's most likely a dirty or defective thermistor, or a blown thermostat. The simplest solution is to replace the fusing unit as a whole, but if you want to save money, you can take the fusing unit out (the black unit on the upper right side, the one that heats up) and using a multimeter, determine if one of the thermostats is bad. Also, check the thermistors (the sensors that lay against the hot roller) for any built-up toner, and check the continuity of the fuser lamp while you have the unit opened up.
SOURCE: I need the reset procedure
This is how you reset that error:
press the yellow "C" button
enter 107
press the red "C" button and keep it hold till the display changes
turn the power off with the big red switch on the unit
turn power on again
Thanks much - if somehow that doesnt work please reply.
Tim
