In baking rusks I need to replace 2 cups/500gm of brown sugar with honey. How many ml of honey will that be?
About 237 ml, or one cup of honey, being it is twice as sweet as sugar.
Addendum: Honey will add extra liquid to your recipe, so you may wish to remedy it by using a little less water. Even after the rusks are baked, however, they may not be as crisp and dry, on account of honeys great humectant properties; it draws moisture from the air. It also can cause breads to scorch easily, especially in a recipe that contains milk, another ingredient with this tendency.
Honey doesn't contains any calories. So, you can add it without having any kind of problem.
If you are looking for better calories options than sugar then honey is the best option for you. For a sweetness of one cup of sugar, you can add 3/4 cup amount of the honey to gain similar sweetness. If you want to get better results then look for darker honey. While it is not necessary to use the honey based on the above factor. The sweetness of the different honey can also be different, so it is better to use it according to your own taste.
Sonia, 316 ml. of honey is equal to 2 cups of sugar.
http://www.beemaid.com/recipe-converter
Billy Bee Sugar to Honey Converter
How to Use Honey in Place of White Sugar
http://convert-to.com/246/honey-amounts-converter.html
