Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
SOURCE: time warner cable, LG TV. volume control
if they are the only buttons that do not work i would say the pcb needs to be cleaned
SOURCE: Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
SOURCE: I need to know what buttons to press on my time
Direct Code Entry
SOURCE: UR5U-8780L DVR remote won't work with Hanspree HSG1102 TV.
no, this is common with remotes, if they program for another unit key features may be missing. Look to see if remote has a search mode that allows you to try each and every code it has one at a time.
SOURCE: Universal Remote: UR5U-8780L - Not Working and CBL Button Constantly Lit
press cable and record buttons at the same time and wait for all the lights to flash in sequence then let go. this will reset remote to factory defaults. then reprogram remote with codes for each device.here is a site for codes. http://www.universalremote.com/resources/pdfs/UR5U-8780L_UR5U-8790L.pdf
