Swann Communications Home & Business Security Monitoring Starter Kit - 4 Channel DVR4-950 / 2 x PNP-150 Day/Night Cameras Logo
Gail Szach Posted on Jun 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Swann dvr4=950 keeps beeping. four beeps. then a pause. how do I stop it and why is it doing it
Sandra Sparks
Level 2:
Sergeant:
  • Expert 180 Answers
  • Posted on Sep 09, 2016
Sandra Sparks
Expert
Level 2:
Sergeant:
Answers
180
Questions
0
Helped
77136
Points
613
Switch the stop button
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
6helpful
3answers
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
My compaq persario sr1000 power is on the fan is on. but it beeps with a short beep and keep on. beeps pause and beeps again all with the power on but no picture on the moniter
Your ram/ram slot may have gone bad, contact Compaq Tech support for detailed instructions.
For a basic idea of what to do if you know what your doing:
1. Pull out 1 ram card in the first slot
2. Start up system
3. If beeping appears leave that slot empty
4. continue until beeping stops
Side Note:
If you keep removing all the ram cards and the beeping continues, I probably got the wrong error.
2helpful
My t42 laptop's screen froze the other day so i turned it off and when i turned it back on the screen stayed black and beeped four beeps then pause then four beeps then pause then four beeps then pause...
keep pushing f2 now youll see the page use arrow keys change your boot log f12 now restart it back up on a f12 now it going ask you do you want run windows go there.
4helpful
No display .. getting three short beeps, pause, one shot beep, pause, four short beeps, pause and another three short beeps.
It's the sound produced by motherboard stating that motherboard is not able to detect the RAM,open the laptop and remove the RAM and clean with a white paper slowly and insert it properly.check it solve your problem otherwise if you have another RAM slot available then try that too. if none work replace with a NEW RAM this will solve your problem
let me know if it's helpful to you
1helpful
Computer will not come on
beeping 4 times in a row is a hardware problem
repalc motherboard if video is intergrated
3helpful
2answers
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Stange beeps
-Reset u r mobile
-Contact motorola care center
Top Swann Communications Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Swann Communications Video Camera Expert? Answer questions, earn points and help others
