Question about Sony STR-DH130 2 Ch Hi-Fi Receiver STRDH130
Can i use wireless speakers with this system - Sony STR-DH130 2 Ch Hi-Fi Receiver STRDH130
  • Sony Master
  • 6,081 Answers
Yes but only if the hi-fi unit either has a built in wireless transmitter or the wireless speakers arrived with a dedicated sender unit to plug into the hi-fi or tv or whatever you need to use them with.
I suggest you begin by reading the two relevant instruction booklets or finding the specifications online.
If there is no sender unit it might be possible to buy a generic wireless sender unit.
Posted on Jun 26, 2016
Testimonial: "thank you"
Anonymous
SOURCE:
I have the philips mcm530 micro system and want to tune in a wireless speaker to the system so I can take the speaker outside. Is that possible?
The philips only receives bt audio it doesn't transmit them. You need a wireless system that includes a receiver and transmitter. The transmitter needs to be able to be connected to the speaker outputs of your philips system. Since I don't know what country you live in it is difficult to recommend anything as what is available in one area may not be available in another
Sep 01, 2016 | Philips Audio Players & Recorders
Can I set up wireless speakers on my bose 321
I'm afraid this unit does not have the capability for wireless. It would have to have a dedicated transmitter and specifically dedicated wireless speakers with the correct firmware(software that links the Bose to the wireless) Some home theater systems use rear wireless speakers, but not this one. Sorry.
Jun 02, 2014 | Bose 3 2 1 GSX System
Have wireless router. need adapter for old hard wired computer speakers
You can't use a wireless adapter like one you connect to a laptop or PC. Simple reason is that your speakers don't have an Operating System that can translate the wireless signal.
The easiest way (and I don't know what you call "reasonable priced") is to use Airport Express from Apple. A nice how-to can be found here. You can get them used for about 50$.
Another option is to use Sony HomeShare Wi-Fi Network Speakers - they cost about the same. Example here and a little how-to here.
Hope this helps - let me know if you have any questions.
Jan 08, 2013 | Computers & Internet
Panasonic Wireless Rear Speakers Ticking
move ur speakers around. if the noise is absent on some places u can be sure its the digital box. or one fix that might work is - get aluminium foils and wrap ur speakers. this can blank out interferences. if that works, open ur speakers and line the walls with thick aluminium foils. hope this helps.
Apr 13, 2010 | Panasonic Home Theater System System
Hook up brookstone wireless outdoor speaker
You cannot add other brand speakers to Bose systems. You must purchase the Bose second zone speaker amp and speakers.
Apr 26, 2009 | Bose (321GS) System
Sonos wireless system
yes, you will need speaker wires
Jan 27, 2009 | Yamaha YSP-900BL Projector
Sony bravia wireless speakers won't pair? ANy answers?
You might try setting the wireless to a different channel. Mine did not work at all on "A" but worked fine on "B".
Dec 26, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Wireless speakers won't connect
You try upgrade the main set to 5.1 or 7.1 channel is it?
If the wireless is green light mean the main set is recognize the wireless.
You need to setup the speaker output from main set by "Setup" button on remote control.
Can refer Operating instruction manual in main set.
Nov 29, 2008 | Panasonic Home Theater System System
Panasonic wireless speakers
did you play with the settings on the remote? turn the pro logic on.
Aug 08, 2008 | Panasonic SC-PT960 Theater System with...
Sony STR-DH130 2 Ch Hi-Fi Receiver STRDH130 Logo
527 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
