Removal of transistors audio 2sb1344/2sd2025/2sb1588/2sd2439, but did not open
SOURCE: my aiwa stereo will not
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
SOURCE: it does not power up although the red lead indicator for power lights up
check one by one power output transistors.
-alexis j. marcojos-
Thanks for all the problem was in the IC Microprocessor panel ic876580W Short between vdd 4.5v and vss
With Regards
Abdulgader Ahmed
From Sudan
