HP LaserJet 3800n Printer Logo
R
Richard Wimbourne Posted on Jun 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
49.2FCC Service Error - HP LaserJet 3800n Printer
Seeker5211
Level 3:
Genius:
  • Master 1,089 Answers
  • Posted on Jul 13, 2016
Seeker5211
Master
Level 3:
Genius:
Answers
1089
Questions
Helped
617363
Points
2611
Power off the printer.
Clear the print queue.
Power on the printer and print.
Mark Schmit
Level 3:
  • HP Master 1,915 Answers
  • Posted on Jun 30, 2016
Mark Schmit
HP Master
Level 3:
Answers
1915
Questions
0
Helped
753253
Points
7967
You need to update the firmware on the printer. go to HP.com and go to the support section and download the current firmware and follow the instructions. Note that the printer will have to be at ready to do this which means you will likely need to restart the printer after clearing any print jobs from the queue on your computer.
Chassis settings service required error message. 2007 v70R with all OEM shocks and alighnment done about 1K miles later the error message comes on.
About 3,440 results (0.84 seconds) Search Results
    Chassis Settings Service Required - Page 2 - 2004 - 2007 V70R ...
    v70r.com > Home > Volvo > 2004 - 2007 V70R
    Nov 1, 2011 - So, in our case it seems that the shock / strut itself is totally undamaged (at .... As usual, the "chassis setting service required" message didn't show as I ....All of them will indeed need to be replaced when normal weeping ..... Error codes 0115 and 0201 can be related to a low battery, but 0023 and 0113 ...Missing: oem
    www.fixya.com/cars/t26080647-chassis_settings_service_required_error
    1 hour ago - Chassis settings service required error message. 2007 v70R with all OEM shocks and alighnment done about 1K miles later the error message ...
    Volvo S60 R "Chassis settings service required" warning - Swedespeed
    forums.swedespeed.com > Forum > Ask IPD > General Maintenance
    Sep 26, 2008 - 29 posts - ‎15 authors
    Now I have this message "chassis setting service required" Did the guys hit ... My way costly Volvo Service Department wants me to bring the car in for ... The explanation was that there is a defective shock and they ... First try was to replace a strut that gave a error. ... All is back to normal. .... 2004 V70R - GT. "Anti-Skid Service Required"
    Dec 22, 2012
    "chassis settings service required"
    Sep 4, 2012
    Another "Chassis Settings Service Required" thread
    Aug 13, 2012
    AntiSkid Service Required and Chasis Settings ...
    Dec 5, 2
2helpful
3answers
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
1helpful
2answers
Error call service 4000:00433933
i have 7410 error call service. i tried to clean everithing en replaced the tone is almost full- still getting the error message.hat can i do. (fs-3900dn)
Please call for service
If the machine is saying "Please Call Service"..you will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Mssge will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common( given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts.
28helpful
6answers
Message is Service call error 00010014
SERVICE CALL 00010014
Description
Failure of pressurizing
My OKI printer is giving me a message which reads, "Service Call 106: Fatal Error".
YYYY
106: FATAL ERROR
An error has
occurred which
requires service.
YYYY = the general
cause. 106 = error
number.
Try turning off the
printer then turning it
back on. If this does
not remedy the
problem, write down
the message including
the error number
“106,” then call your
authorized Oki Data
Service Dealer for
service.
Note: If you see a
series of octets
containing letters and
numbers scrolling
across the display, be
sure to write these
down also and report
them to the Service
Fuser error. Replace fuser or if no-go, Main board.
1helpful
2answers
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
2answers
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
k24674
Grand Canyon Tech
Grand Canyon Tech
