Question about Panasonic Lumix Cameras
Flash wont pop out, even if i push the flash button at the back of my camera
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
It won't pop out in certain exposure modes, like manual. Try it on auto. If not, GENTLY try to pry it up - sometimes they get stuck from dirt of being hit.
Posted on Jul 03, 2016
6ya staff
SOURCE:
Anonymous
  • 148 Answers
SOURCE: eos 300D. THE FLASH DOESN`T POP UP
there is a setting that tells the camera to use flash or not to. refer to manual. its simple to remedy.
good luck
mark
Posted on Dec 23, 2007
Anonymous
  • 4 Answers
SOURCE: Shutter button problem
This may be the same problem that requires you to press the LOCK button to actually take a picture. I found a solution and have posted to the questions mentioning the LOCK problem. Anyways, here goes, if that is not the problem please disregard what follows:
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
Posted on Jan 22, 2009
Anonymous
  • 71 Answers
SOURCE: my canon xsi on camera flash won't pop upeven after i press flash
I would suggest taking it to a technician to have it repaired. It does not seem like something you should try to fix yourself.
Posted on Jun 20, 2009
Anonymous
  • 15 Answers
SOURCE: Olympus evolt 500 - Flash won't pop up
did you have the auto pop up in the menu on?
Posted on Jun 29, 2009
Anonymous
  • 3 Answers
SOURCE: doesn't turn on, red light & flash pops up
most probably your charger inside the camera has gone bad. Get an expernal samsung charger.
Posted on Jul 06, 2009
Nikon D5100 camera flash does not pop-up. Any suggestions?
You can't pop up the flash in the Auto mode. In this mode the camera decides whether to use the flash or not.
Try switching to one of the PSAM modes. Does the flash then pop up when you push the flash button?
Jan 17, 2014 | Nikon D5100 Digital Camera
Internal flash won't work anymore
Try a factory reset. In the menu go to the third spanner and select 'Clear settings'
To pop up the flash put the camera in manual mode (M) and press the flash release button and it should pop up.
Oct 15, 2017 | Canon EOS 600D Rebel T3i Digital Camera
When I try to take a picture the camera tries 2 or 3 times then I get a err05. (built in flash auto pop-up was iobtructed.) But I can't find anything obstructing it
Alot of times there is residue that has got stuck in between the flash cover and top cover. Turn the camera on and with your nail pry open the flash as you push the flash pop up button with your other hand! Then with alcohol and a couple of q-tips clean every part under the flash pop up. When the camera is facing you there is a arm that rests slightly forward on the left side clean there and on the right side in the back there is a piece of plastic sticking out of the cover. Its black in color clean that with alcohol depress it a few times with the q-tip soaked in alcohol and the arms that push up the flash are silver, clean those real good. Alot of times when a camera is sent in for this it is usually a result of residue of some sort getting in between the flash pop up and the top cover! Even if it looks clean, clean it anyways. Also sometimes the flash pop up is slightly bent you can bend it in place with your hand. Just a little a a time and then try to depress the flash pop up button and see if it works.
Jun 18, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Flash will not close on Canon EOS 7D
All you need to do is set the camera to shutter priority other non-automatic mode, hold the flash shut and hold the flash button next to the lens opening. You'll hear a motor and a click and it should latch shut.
Jan 30, 2010 | Canon EOS 7D Digital Camera
My Rebel T1i's built in flash stopped working after I used a 580EX external flash on it. It won't even show up on the LCD screen.
Really? the best solution available is to take the top of your camera off?
i don't think so.
Here's a very simple solution I found to get the flash to pop up without destroying your camera.
http://forums.dpreview.com/forums/read.asp?forum=1031&message=31993875
the person suggests using a fingernail. (s)he must have long fingernails. I had to use a piece of paper folded in half. Swipe the paper from back to front, as in, from the eyepiece side towards the lens side.
Here's a picture: http://www.flickr.com/photos/dougpardee/133066175/
good luck
Sep 25, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Jun 20, 2009 | Olympus EVOLT E-500 Digital Camera
Flash doesn't work
Check your flash setting (the button with a jagged lightning bolt) to make sure that you have the camera set for auto flash. Push the flash setting button until you see a bold A next to the lightning bolt. Sometimes the user inadvertently covers or even just touches the flash unit while powering on the camera, preventing the unit from popping up. Many Kodak cameras have a manual button (marked with the lightning bolt and the word OPEN) to pop the unit up so that it will work for you. Hope this helps.
Bill B.
San Antonio
May 05, 2009 | Kodak EasyShare Z1012 IS Digital Camera
Canon XTi Built in Flash
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Feb 09, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Flash
Jan 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Eos 300D. THE FLASH DOESN`T POP UP
good luck
mark
Dec 08, 2007 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
63 people viewed this question
Top Panasonic Cameras Experts
Ekse
Tom Chichester
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
