SOURCE: reset kurio 7 tablet to factory settings
press and hold VOL+ and Power button simultaneiously.
http://www.kurioworld.com/us/pdf/Kurio_Manual_US.pdf
Take it back to the generous person who gave it to you and ask her to try hard to remember the password or to unlock it for you so that you can change the pattern. Or contact the manufacturer's service center.
SOURCE: How to do hard reset on tablet without volume
If it can boot, use Backup & reset option on the latest versions of Android or Privacy under older versions
Do you mean that the PIN of the SIM card is locked?
The PIN is needed to access the SIM card.
If you remove the SIM card the tablet will not ask for a PIN.
You do not need to change anything in the tablet.
(If you would insert your SIM card in a phone, the same would happen when you launch the phone.)
I hope this helps.
Testimonial: "The tablet does not have a sim card. Just a basic tablet with a number password instead of a pattern. many thanks"
SOURCE: I have a nobis Tablet.I tried to do a hard reset
guess is that the float level is not closing (need to open float bowl and clean everything inside with carb cleaner. Confirm that the float is operating (up and down) . Reassemble and try again...should be fine.
