Check the lines good and change the fuel filters. Look for line leaks, holes, or poor fittings on all ends. You may be sucking in debris within the lines and this could be a problem. Also water in the lines or bad gas can damage filter and pumps. Use Gas additives.
sometimes oxygen sensor can trip different lights coming on, you could try changing that to see if it stops it, if not could be some type of fuse tripping the electrical system.
did they replace the fuel pressure sensor. as this could be the problem. it could be over pressure or underpressure, that could be the regulator is blocked or the injector filter is clogged. but if no change in any driving needs then would just think it was the sensor as the others would limit fuel.
I have a a V8 Tundra.
Driver side front. You may have to remove skid plate.
Also try turning front wheel hard to the left and look behind the left wheel and you see it.
