O Techwood tv built in freeview on two channels is comes up bbc wales instead of BB1 and how do i get them back to BBC2 and BBC2 Thank you very much all HELP NEEDED
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
SOURCE: Missing Channels
I have found that for some reason bbc brodcasts are not transmitted in hd,either on sat or cable
SOURCE: Teletext
With your cable box turned OFF press the menu button on the box itself (not the remote) it will take you to a hidden menu. Turn off the CC.
SOURCE: Toshiba 19DV500 b will only
Hi, sounds like you are in Analouge mode and not in DTV mode so you can't access the DTV menu to tune in the tv.
Press the 'SOURCE' button and move to DTV using the arrow keys, then press ok and if channels aren't already tuned you will now be able to tune them by accessing the DTV menu by pressing the 'MENU' key on the remote control.
If you don't have the manual you can download it or view it by clicking ----> HERE
Hope this helps.
SOURCE: panasonic lcd tv model no.
This This is a difficult one . You may have to go online to get an Upgrade for the TV..You will need a flash drive and of course there must be a USB socket on your tv... Other than that im stumped. Sorry.
hope this helps
SOURCE: My Philips hdt8520 has lost
This happened to us. we reset the box to factory settings and all channels came back. hope this helps
