SOURCE: I have a samsung smart tv and a samsung galaxy s
Reset your TV.
With the power off - use the remote and push mute + 1 + 8 + 2 + power button.
When the set turns on, you will see a menu pop up. Just hit enter on the remote and you will see Factory reset. Hit enter again and the TV will reset.
sounds like a bad mainboard.
SOURCE: What is the best remote for vizio 70" LED smart tv?
Get a Harmony, there are several models depending on the number of devices you want to control.
Testimonial: "Good answer, I needed a brand recommendation. Thanks."
SOURCE: Luxor LUX0150001B/01 50 inch LED Smart TV
What is the problem you faces with this TV? Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: Ihhave a 32 inch Luxor smart TV and I need to reset it back to factory settings can anyone help me?
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
