Try contacting the security alarm company for assistance. ADT used this system in the past. You may also want to try a local security service to see if they can source the parts for you.
Just bring the fuse to the electronic store and let them find them the exact fuse that you needed for replacement. or bring your device to a reliable technician so you'll have a guarantee that if ever the fuse replacement is wrong he will be responsible for the in correct replacement of the fuse in your device so he will do something about it...Hope it will help you
These alarm panels receive 16.5 VAC from a small wall adapter that is wired into the keybus and labeled 'AC'. Have a certified alarm company or installer check your system for faults and get things in order.
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
If you know the 'go' code ( default 9713 ), you can press *+90 to see the event log, which you scroll through with the arrow keys on the keypad (alpha keypads only). If that is not available, you will need to have a certified alarm installer come and check your system for faults.
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
