Televison & Video Logo
GAME GLAMOROUS Posted on Jul 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Blu phone hit the wall and now a black screen appears with a white line going vertically down the middle. How can I get the screen to get back to normal?
Mallika
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 18, 2019
Mallika
Contributor
Level 1:
Answers
Questions
0
Helped
220
Points
Vernon Taylor
Level 3:
  • Televison & ... Master 7,446 Answers
  • Posted on Jul 05, 2016
 Vernon Taylor
Level 3:
Answers
7446
Questions
0
Helped
1957507
Points
26207
I believe your phone needs taking to the phone doctor who will probably diagnose a new screen required.
5 Related Answers
Anonymous
  • Posted on Feb 07, 2009
SOURCE: BLACK LINE
same problem 2 inch vertical line in center of screen! could this be something loose in the back??
Anonymous
  • 64 Answers
  • Posted on May 25, 2009
SOURCE: samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Anonymous
  • 80 Answers
  • Posted on Jun 01, 2009
SOURCE: Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Anonymous
  • 7 Answers
  • Posted on Dec 31, 2009
SOURCE: line accross top of the screen with flashing black and white boxes
Go to menu and settings and look for OVERSCAN and set this to on and hey presto no more white lines no matter what ratio your in.
Anonymous
  • Posted on Sep 28, 2010
SOURCE: Mines a LG RZ42PX11 it intermittently gets a black
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
3answers
I have a 55in roku tcl tv has a black line going down the middle and beside that is a bunch of colored lines on one side what is this
I would think that someone, somehow has hit the TV screen with something. My TV screen has a black line going across the middle horizontally and it intersects with a colored line going down the side vertically. Wher the 2 lines intersect is where it was shot with a bb.
White vertical lines like jail bars
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
A gap appears as a column down the page
I would check for an actual foreign object in the carrier
8helpful
3answers
Samsung 42" Plasma -Black vertical line when turned on.
2answers
Vertical lines down center of Plasma TV
Because of the complexity of these sets, the fault can be much more than just a bad IC. These sets are serviced at the board level. After changing the board, calibration is done as necessary.
The fault may be in the matrix power driver output area, or in the plasma screen back-plane layer itself. This has to be determined by the process of elimination.
I can tell you in advance that this will not be a low cost repair.
Jerry G.
2answers
Theres a line threw my tv.
It has a problem in the vertical sweep circuit that puts a nonlinearity in its output and you see the glitch in the normally gradual sweep as a line. Since a hit upside the set seems to help, you should just resolder the whole vertical circuit area (doesn't take long) and see if that cures it. If not, start replacing the electrolytic capacitors in that area.
Hope Ya Fix It!
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
