? 2:08
https://www.youtube.com/watch?v=fSIuoh_bZN4
Mar 9, 2010 - Uploaded by Epictreadmillowner
epic view 550 treadmill video 2 ... ICON Canada doesn't really support this and the independant technicians ...Epictreadmillowner 1,181 views.
? 3:02
https://www.youtube.com/watch?v=kNiFOcrV9r4
Nov 29, 2012 - Uploaded by Treadmill Review Guru
... .com/epic-treadmill-reviews/epic-view-550-treadmill-reviews-ratings/ ... Nordic track has the track and google maps by i-fit you can download and run anywhere ... The review says it doesn'thave the track/lap but it does.
? 1:59
https://www.youtube.com/watch?v=YjqgZS-1qlw
Mar 11, 2010 - Uploaded by Epictreadmillowner
Epic View 550 Treadmill video 3. Epictreadmillowner ... I have had 3 different console units, and now the tv doesn't work either!
adjust the REED swtich, test it for open or faulty, clean it , and tight the plug very well. see the diagram attached. Plug the ribbon cable for keypads very well, and clean it. God bless you
hold the stop button and then insert the key, keep holding the stop button until you see the mileage and hours used, to switch from English measurement to metric just hit speed up button.
Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch to the reset position.
Check to see if the motor is spinning. If not spinning, then use a voltmeter to find out the voltage of power going to the motor that spins the belt. See if you can rotate it by hand.
Check the motor and the gears that run the unit up and down. If is located on the front of the unit under the face plate. make sure everything is power everything. Also check the gears to make sure they did not break and check the tracks to make sure it did not fall off the track causing it to stay up
