The power supply appears to feed the LEDs directly. Is that correct?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
SOURCE: DIBOSS tv shows no picture
Me too! Apparently Diboss are no longer trading, so no help there. I am aware that these panels have a common power supply issue, the faulty chip is only available from China and the last one I fitted only lastest a couple of days. However the fault described above is not the same. I've checked the psu outputs; all are fine and nothing changes when the picture disappears, therefore I can assume that I'm not looking at a PSU fault. As Iain says above, it appears to be a signal link, however I have no picture on ANY input and without circuit diagrams I cannot find any component that's common to all the various inputs. This leads me to think that either the backlight, or the screen itself is faulty. I'll keep trying and if I get it sorted I will report back.
Jon
SOURCE: tv guide on our LG tv
If, when selecting the guide, the entire screen is black (except for the preview in the corner), then the digital main board has gone bad and will need replaced.
Hope this helps, please rate my solution.
SOURCE: No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
SOURCE: LG 42PX4MVH PLASMA TV - Sound but no picture.
I have the same issue with my LG 42PC3DVA and I narrowed it down to the Y SUS board. After a little research there are a few items that are prone to go. The ceramic fuses (as you found), sometimes the capacitors on the Y SUS, Z SUS, and power supply go along with them You can tell because thy will be bulged at the top instead of flat. I replaced a few of my capacitors - they are only $0.89 each so it was MUCH cheaper than a board.
The other thing that is common on the Y SUS in particular are the FETs (also called MOSFET). They can be replaced if you are good with a soldering gun but they are static sensitive so be grounded. They are also a bit tricky to test so you may want to do some research on how to determine if this is the issue... or you can just replace the whole board.
SOURCE: LG 50 IN. PLASMA TV MODEL # 50PC1DR . POWER
Power supply board is dead,replaced the power supply board will get power.
