Question about Coby Kyros MID7012-4G 7" Tablet, Telechips ARM 11, 4GB Storage, M
I bought a coby mid7012 which is in great shape but completely outdated. how to i update it's firmware or software or just update it?
Have a 10gb sd...i know i can update from the sd.. but i cant figure out how. if there is anyway i can just update, please help
2 Suggested Answers
6ya staff
SOURCE:
Zachary Foraker
  • 7 Answers
SOURCE: how can i print coby kyros manual
the manufacturing company always has the manuals or maybe even the drivers you need. so go to the coby webpage and search for your MID for your tablet and you should be able to find it quite easily.
Posted on Sep 17, 2012
How to fix kyros coby mid8024 tablet
Sounds like a corrupted kernel. The only thing you can do is download adb tools and then download the original Coby files for android. without having to do alot of research(if you dont know how to, you will have to research) you can go to Androidcentral.com go to the coby section, in the forum. There you should be able to find the step by step method. Sorry but this would be about the best help I can give you with out actually doing it myself.
May 10, 2015 | Coby Kyros MID80244G Tablet
Restore setting after reset
you can only restore what you have backed up on sd or the cloud. anyways just go to your file manager and move whatever is on your sd to internal memory. or go to cloud website and download from there
Dec 07, 2014 | Nextbook Tablets & eReaders
How do i reset kurio 7 to factory settings?
that is what happened to me. its because its a really junky tablet.
Jul 14, 2014 | Techno Source Kurio Kids Tablet With...
Problem with V. 811 Onda Tablet
hi Akram.
this is all i could find out.
When the tablet is turned off, keep home button pressed.
Now turn on tablet while still holding the home button.
When white android figure appears, release both buttons.
You will get into recovery mode, you can select "restore factory settings" there.
Download the right firmware here: ONDA
Extract the content to the root of your sd card (since you cannot use your tablet, i suggest using a cardreader + pc or another tablet? or try to hook your tablet to the pc and hope it recognizes it)
There should be 5-6 files now on your SD card.
Turn on tablet while holding home button, untill white android figure appears then release.
It should update your firmware now...
or you could try this link on how to do a hard reset.
but do so at your own risk.
Onda V811 hard reset format factory mod recovery rom install ..
or try this link for more info.
hard reset tablet onda v811 Google Search
or this one.
811 Onda Tablet logo screen white Google Search
Nov 27, 2017 | Tablets & eReaders
How to update my firmweare
You need to know first if your device is "rooted". If it is, do not proceed.
I also have an Android but it's a smaller one but I would assume things are identical if not the same. Anyways, look for the cogwheel or anyway that you can access the settings, scroll all the way down and tap on "About Device". The first thing that comes up is "Software Update". I hope that helped.
Dec 17, 2013 | Mach Speed Trio Stealth G2 Tablet -...
I cant remember my cruz pattern to sign into the whole system. what can i do?
There isn't anyway to bypass the security pattern on an android device. So basically the only option you would have is to do a factory restore and start from the beginning. You can also use this opportunity to update to the newest firmware if you haven't done so.
The update can be downloaded from here. After downloading copy it to the root (not in a folder) of an SD card ensuring that the file is named 'PD_INX7E_ENG_6410POP.ZIP'.
Insert your SD card into the external SD slot on the device. With the device off, press and hold the volume up button. While continuing to hold the volume up button, press and hold the power button. Continue holding both buttons. The 'Cruz' screen will come up and then an android screen with a status meter will come up. Now release both buttons and let the update apply. When it's done the device will reboot and should start normally.
This does clear the internal memory of the device, so you will lose all the programs that you've installed. Any data on the internal SD card and external SD card will not be touched.
I hope this helps. Let me know if you have any questions.
Ray
May 17, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Coby Kyros MID7012-4G 7" Tablet, Telechips ARM 11, 4GB Storage, M Logo
71 people viewed this question
Top Coby Tablets & eReaders Experts
 Mike M
Mike M
Marvin
Marvin
Lawrence Oravetz
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
