I have a phillips tv model# 42hf9745d/27 I was watching tv and the power turned off tv I turned it back on the standby light comes on green but no picture need help to solve problem please.
    Habit-Forming:
    New Friend:
  • 10 Answers
Sounds like it could be a power surge issue. When the power came back on it could have over loaded your TV shorting out parts of the tv.
Does anything come on the screen at all? Do you get a logo when it turns on? Can you access a menu at all? Can you try plugging in a different device (DVD player etc) and get a signal?
If you're able to get a menu or logo to come on, then it could be a cable issue. Check that the cables are secure on the TV and other devices. If they're good then the TV is most likely fried.
Posted on Jul 11, 2016
6ya staff
SOURCE:
Anonymous
SOURCE: Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Posted on Oct 03, 2007
Anonymous
SOURCE: Goodmans LD26450HD
i have same problem with mine on ld2650hd
Posted on Jan 14, 2008
Anonymous
  • 3 Answers
SOURCE: my power light on hitachi lcd is flashing red and
Sadly to the end I can now explain the "problem" of my question by myself ...
Because I'm was not sure if I can handle the "problem" by myself I gave the Screen to a technican at our City with all the Information I found until this point (By the way my suspicion was the defect of something at the power supply unit). Two days later he gave me a call with the information about the error: An error at the power supply unit - spare parts => 50€, Work => 200€).
Unhappily im not yet got at soldering on screens, but for 250€ i would have made a good course for this (and if I can establish i will learn it).
So now again a bit more objectively:
Error / Problem:
TV - Step 1: Power Off
TV - Step 2: Stand-By
TV - Step 3: Power-On
TV - Step 4: Short flashing picture
TV - Step 5: Reverse to Step 1
Solution:
1. Find the defect Fuse/Safe/...
2. Buy the Spare part at eshop2.euras.com
3. Change the parts -> et voilá
Hopefully I could have been a little help for someone.
With kind regards,
NatureOneFreak
Posted on May 30, 2009
vinnyq
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Posted on Oct 19, 2009
Phillips 39" tv problem
a power surge can do alot of damage but does your model have a fused plug? as would check this. if you have changed the power board for a know working one then the main av board has gone this is the board that tells the power board to turn on.
Jul 15, 2017 | Televison & Video
My magnavox tv model num 50mf231d137 will not turn on it turns on then turns off with red light blinking
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information google.com/+GopakumarGopalan
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Televison & Video
Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Jan 15, 2010 | Thomson LCDB 03B 27 in. Television
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
T.V won't turn back on
Sounds like a component shorted out for sure. I will guess he will say, "It needs a new power board". I would guess a transistor or microchip burnt out. Probably ESD damage from a new factory worker.
Nov 14, 2008 | Televison & Video
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
