The lines are more visible on the left side of the screen and get dimmer as it nears the right side. Tried HDMI and the WWW. modes and it happens in both.
I hate to give you bad news but about 90% of the time horizontal lines come from a bad panel and if that's the case the set isn't worth fixing as a panel costs hundreds of dollars
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
I hate to give you bad news but I believe this will be a panel issue and it's not going to be fixable. You can try a different tcon board but I don't think it will help
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Check the ribbon cables in side the TV that connect to the panel. They are the left side looking at the back. Make sure they are all seated propporly. If that does not fix, then your Upper Y Buffer board needs to be replaced.
Hello. It looks like problem is originated near buffer board/s. You can try to repair this but it is not recommended for untrained person. If you remove back cover of your TV on the left hand side you will find ribbon cables that connected to narrow and long buffer board (or two boards) with one end while other end goes inside PDP (Plasma Display Panel). Poor connection could be present on any side of that ribbon cables. You can try to "play" with ones that are visible and see if it will clear the picture while TV is turned on. But this is not safe, there is about 200V running on some boards so you have to be extremely careful. If poor connection is on the other side of the cable - than issue is impossible to fix without replacing whole panel. And this is more expensive than just buy a new TV. I would recommend let professional to take a look at it. Your health and life is not worth of any TV set out there. regards. Russ.
