The load has become unbalanced. Pause the machine in mid-cycle (do not Stop it) and when it ceases spinning, open it and re-distribute the load evenly. Then press Pause again to continue the cycle. Note: if you Stop it, then restart when finished balancing, the machine will start washing from the beginning instead of continuing from where you Paused it.
This is a motor fault issue.
As I don't know your ability in repairing or what tools you possess.
Simple solution: other then have a repairman do this, the motor has something causing a fault. The vast majority of times in an asko because the motors spin at high speeds then most others is that the brushes wear out. So they most likely need a repair. Turn off machine, remove motor replace brushes.
There other possibilities such as electrical problems but I reckon brushes are the problem, could cost $60 for the pair and takes maybe an hour or two depending the skill of the person attempting.
This is not complex just dirty
I do not endorse repairing any appliance without proper experience in repairing appliances. This is only informative.
can you start the unit without any clothes in it, let it fill with water as usual and then observe if it tumbles in both directions during the wash cycle ? ( I don't mean the entire cycle, just long enough to insure it rotates in both direction ). Then turn it to drain and insure it drains completely, observe the spin cycle if you can and report if it only spins in one direction slowly. This will go a long way in diagnosing your Asko washer.
Let me know what you find. If it only goes one way, the motor needs new brushes and possibly a complete motor if the armiture is damaged.
Good luck.
Macmarkus :)
Hi, I am the new owner of a used Asko
Cylinda 10504. The last owner briefly demonstrated
the washer starting a wash cycle and entering the agitation cycle of the wash
before stopping and pumping the water out and spinning in a final end
cycle.I bought it.I had the machine installed turned it
on and cannot get it to go through the wash cycle.After starting at #1 it goes through a perpetual spin cycle
of sorts--water and soap soaking the drum and laundry but not enough water to
fill up half way or less.It stops
at number 4 on the program knob sits on a red dot (next to the #4) and does
nothing.I then manually move it
to the next cycle and it repeats the spin cycle again until I have advanced the
program to the end.No wash cycle
no rinse cycle.Nothing.When it advances to the red dot I wait
for at least 5 minutes before manually advancing the knob.The instructions say that I should get
the water pumped out by turning the program knob to #7 or #9 but in both cases
it just spins and does no empty or finish in the end spin cycle of several (9?)
minutes.Nothing but banging and
spinning.The water seems to get
into the drum as well as the detergent but nothing else is happening. No mater where I start the program it
spins and sloshes soapy water, pumping almost nothing out. Any suggestions short of putting it on
the curb or paying a kings ransom to fly a tech out to look at it? MY GUESS. It seems that it is repeating the same
brief cycle over and over.During
the move to my house the electronics re set(??!?!?) and now need to be set to
the normal mode after being re connected? Can you help? Blessings, Douglas
hi sir'
start the wash machine empty and see if it happens when nothing is in it. 2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine) 3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
