Question about LG 37LC7D 37 in. LCD HDTV
LCD TV - INTERMITANT BLUE SCREEN
TV powers on no issue, clear feed. After 2 mins it goes blue and stays blue about 5 mins then regular feed/image comes back. Almost like it works when cold and when warm, but the in between phase it loses image.
  • LG Master
  • 6,694 Answers
Fault in the main board. You have to replace the main board. As it's have SMD components is would be difficult to repair.
If you wish to get some more details then check the following link.
http://electro-medical.blogspot.com/
Posted on Jul 13, 2016
6ya staff
SOURCE:
The LED back lights will not stay on. I have sound and I can see an image with a flashlight.
inverter board is most likely the culprit since it feeds power to the backlights.
Jun 08, 2016 | LG Televison & Video
I have an RCA projection TV, model D52W19B. The TV powers on ok, stays on, and audio is normal. I don't get a picture. If I press the menu button, the menu will appear on the screen normally.
my guess is you either have a satellite or cable box try unplugging the system cable or satellite and set for 5 minutes and then plug them back and and restart the unit up and see if it comes back the gemstar module would some times lock up causing this problem . and please let me know if that get's you working or if there is more trouble shooting to be done
Nov 03, 2014 | RCA Televison & Video
I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
Mar 21, 2011 | Element Electronics FLX3210 32 in. LCD TV
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Jul 11, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
My 2001 Mitsubishi Medallion recently stopped recieveing HD channel from my FIOS HDTV Box. When switching from standard channels(they work) to an HD channel, the screen shows scrambled mutltiple images and...
If the TV works in the "Other" modes than I would suspect, that the FIOS HDTV box has developed some fault. When a TV goes to a "Blue Screen" this means that it cannot interpret a proper signal, maybe you need to reset the FIOS, anyway check that out, the TV itself, I do NOT think is faulty, check connections, antenna and to TV as well. Unplug ALL from wall wait 5 mins, and power back up, this often fixes a lot or problems.
R - Restore: Restore default settings E - Environment: Change your environment, remove from media cabinet, try different media, try different equipment (TV, router, hotspot, etc.). P - Power Cycle: Power cycle by unplugging your networking equipment from wall for 2 minutes to reset. A - Access this Knowledge Center for useful articles to resolve issues. I - Install the latest System Software Update. R - Resolved: In most cases these steps can resolve your issue.
Apr 01, 2010 | Televison & Video
Will not switch on
There's a problem with the video card of the lcd TV  needs replacement .
some chip are damaged .or gets over heated eg processor .
Good luck
Oct 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
New Blue CRT installed now TV won't stay on
sounds like the HV lead isnt sealed properly either at the CRT or the Splitter I would have him come back and recheck his connections
Jun 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
LG 37LC7D 37 in. LCD HDTV Logo
35 people viewed this question
Ekse
RONALD CARTER JR
