SOURCE: Uniden Bearcat BC60XLT 10 Channel 10 Band Radio Scanner with L/O on every channel #
Hi - You can download the manual by clicking the link underlined in blue below:
bc60XLT
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: i cant reprogram my channels back in ,think its locked
Here is a link to get the full manual... it should allow you to remove the lo on the channels... www.uniden.com/pdf/BC60XLTom.pdf
SOURCE: need a starter frequency guide
The best frequency database is at
www.radioreference.com
Testimonial: "thanks that worked!"
SOURCE: i have an uniden bearcat 30channel 10 band
For some unknown reason, Uniden assigned a very similar model number to two very different scanners. The 30 channel scanner you have is a BC60XLT-1, where the 10 channel version is a BC60XLT.
The manual for the BC60XLT-1 can be found at this link:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
Turn off power, hold down the 2, 9 & L/O buttons while turning the power back on.
